Results 1 to 5 of 5
    Dec 2019
    Australia
    65
    2
    Default Old old transtig 180 surge filter
    Hi all. I have an early 90s CIGWELD transtig 180 that has broken down. After finishing an ally weld while the welder was cooling it popped the CB. Investigation found what I think is a surge filter had overheated and burst probably shorting out causing the CB to trip. It is attached directly to the active, neutral and earth at the mains input point. The welder fires up without it in the circuit but I am not game to try welding without it just in case I damage the welder. I can't identify this filter nor find any info on the web. Local electrical stores look at me blankly. It almost looks like a clear plastic fluorescent light starter and about the same size. It is wired red, black and earth to two flat capacitors then to the corresponding colour input wires in parallel. Can anyone identify it. A name and specs would be good as it is so old I may have to put an alternative in. Any help would be much appreciated. Thanks.
    Nov 2007
    Near Rockhampton
    270
    Quote Originally Posted by wasanne View Post
    Hi. My Transtig 180 is long gone so I can't check out an undamaged unit for comparison.
    The damaged part may be used to prevent electrical noise from the high frequency section of the welder making it's way back into the mains wiring.
    Sorry I can't be any more help.
    Jun 2010
    Canberra
    1,322
    The "capacitors" on the back look like MOVs for surge suppression (if the voltage exceeds a threshold, say 400V, they become conductive and shunt the current to earth). The three-leaded cylinder most likely has a similar role, perhaps filtering high frequency noise, as suggested.
    Dec 2019
    Australia
    65
    2
    Thanks guys. Anyone have any idea on what the outcome might be if I was to use the welder without this in the circuit. I have a transmig 195 as well both bought new around 1990 but it doesn't have the same setup so leaning towards something to do with the HF.
    Jun 2010
    Canberra
    1,322
    I think it should be OK to use.
  1. Replies: 8
    Last Post: 15th Sep 2018, 10:27 PM
  2. REM filter
    By th62 in forum METALWORK GENERAL
    Last Post: 8th Aug 2014, 08:55 PM
  3. Swarf filter
    Last Post: 9th Dec 2013, 07:36 AM
  4. Filter lense table
    By specialist in forum WELDING
    Last Post: 19th Jul 2008, 06:59 PM
