Results 16 to 18 of 18
Thread: Cigweld Weldskill 185
10th Jan 2020, 01:52 PM #16New Member
- Sep 2011
- mundubbera
- 76
- 8
13th Jan 2020, 03:18 PM #17Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Welding with electrodes.
Hello from the old goat again.
If you want to store electrodes for extended periods I have found lengths of down pipe fitted with screw on caps best, or mums plastiware. You have to limit the atmosphere exchange as temp changes.
By lead and lag angle I refer to the electrode contact in relation to the holder. With stick rods the electrode tip lags the hand piece. With mig wire the wire tip leads the torch unless using flux cored wire.
Hi iron powder electrodes typically give recovery rates between 135-145% but can suffer more from magnetic arc blow than GP's.
If you can find it on the web a good guide for mig welding is the Liquid Arc Mig/Mag Welding Guide. Document number C4.200LA . It was a Lincoln company here in Aus.
BC
16th Apr 2020, 08:40 PM #18Banned
- Mar 2020
- Sa
- 24
Easy striking is largely due to rod brands I've found: Gemini rods are a bugger, as are the cheap Chinese rods. Lincoln and Michigan, I've found are excellent. If using hard to strike rods you must have a strike plate next to the piece to be welded and strike while the rod is still red hot.
Cigweld Weldskill 150
By glivo in forum WELDINGReplies: 6Last Post: 29th Apr 2019, 06:26 AM -
Cigweld Weldskill 135
By Ziff44 in forum WELDINGReplies: 6Last Post: 7th Feb 2018, 09:29 PM -
Cigweld Weldskill MIG 135 - suitable for carbon steel sheet?
By stu50 in forum WELDINGReplies: 0Last Post: 8th Dec 2013, 01:53 AM -
Cigweld Weldskill not working
By macsko in forum WELDINGReplies: 26Last Post: 9th May 2012, 02:16 AM -
CIGWELD WeldSkill® Auto Darkening Helmet
By DJ’s Timber in forum WELDINGReplies: 12Last Post: 2nd Mar 2009, 08:48 PM
