Results 1 to 8 of 8
Thread: spot welding 18 gauge
18th Dec 2019, 05:22 PM #1
My jeep project is coming along the engine is down at the machine shop ATM . I'll be needing to spot weld 1.2mm panels and 1.6 to 1.2 mm stuff together for the tub repairs. Will a 240 V single phase spot welder be OK for this type of work ? I'm looking for a used machine with suitable amperage .
18th Dec 2019, 06:14 PM #2Philomath in training
It should do it. The key thing will be to make sure that your point tips are small enough so you get decent current density. Check using peel tests.
19th Dec 2019, 12:13 AM #3Most Valued Member
Mike, do you have a MIG welder? If you have, then that can be utilised as one. If you set your nozzle up so that it has 4 "castles", as below, so that they will allow the gas to vent, then push down and apply the trigger. Get some scrap pieces to practice and get your settings and time right. Some of the MIG welders have a setting for spot welding.
HTH.
19th Dec 2019, 02:34 PM #4
ok
Thanks Kryn
This doesn' t sound promising
AutoSpeed - Spot welders for the home workshop, Part 1
25th Dec 2019, 08:54 PM #5
not sure
Is this a spot welder ?
https://www.ebay.com.au/itm/VEVOR-35...edirect=mobile
25th Dec 2019, 10:26 PM #6Philomath in training
Not quite
26th Dec 2019, 08:37 PM #7
A standard method for pulling out small dents and depressions these days is to weld threaded studs into the depression, then screw on a slide hammer to manipulate the metal and pull it back into shape. The studs are then broken off and any residual weld is ground off, aiming to leave a clear surface slightly below the desired finished surface. The slight depression is then filled with a minimal amount of filler and contoured to the final shape.
The gizmo you linked is the welder for placing the studs for the above technique. Functionally it is a spot welder, but the current density and pressure are not adequate to form permanent bonds, they produce a temporary bond intended to broken by twisting the stud with a pair of pliers or vice grips.
For spot welding sheet metal, you are looking to something like this . The tips compress the panels together with a reasonable amount of pressure then a short high current pulse of electricity passes through the tips and compressed metal fusing it together permanently.
Another alternative is to drill/punch holes in one panel, align and clamp the panel, then puddle weld through the holes to the other panel, slightly overfilling the hole and then grinding back to flush.
Hope this helps.I used to be an engineer, I'm not an engineer any more, but on the really good days I can remember when I was.
27th Dec 2019, 02:20 AM #8China
- Dec 2005
- South Australia
- 1,658
While searching for something else entirely I came across this you may want to investigate
https://www.ebay.com.au/itm/Alpha-Sp...ad76%7Ciid%3A2
spot welding in Brisbane
By kenny_10 in forum WELDINGReplies: 3Last Post: 2nd Apr 2019, 12:50 PM -
NZ Swap on the Spot Gas
By KBs PensNmore in forum WELDINGReplies: 2Last Post: 21st Feb 2015, 11:58 AM -
spot welding aluminium
By morrisman in forum WELDINGReplies: 2Last Post: 31st Mar 2013, 11:03 PM -
Spot welding electrodes
By Michael G in forum METALWORK GENERALReplies: 11Last Post: 1st Feb 2012, 06:20 PM -
Spot Welder
By Keith_W in forum WELDINGReplies: 4Last Post: 5th Apr 2009, 09:16 PM
