Results 16 to 22 of 22
Thread: Bossweld Welders
13th Jun 2020, 05:04 PM #16
The machine I've pulled apart often had 2 of them wired in (not a bossweld). Is there a second one to compare it to?
As for wiring them, pretty simple if you know which rectifier you need to install. Solder them with inputs opposite each other, and outputs opposite- I-O-I-O if you were to read it going clockwise. Doesn't matter which wire goes where on the input side as it just inverts the AC waveform. This was for the square format rectifiers. For all intents and purposes, 4 diodes wired in the same config would give the same result, but maybe not the longevity.
Probably a good start to read the markings on your rectifier and dig up a tech sheet for that product online thru somewhere like RS components, mouser, or similar.
13th Jun 2020, 06:14 PM #17
Some pictures here of Bossweld MIG 186 PCB.
https://www.bobthewelder.com.au/PCB-...ig186-156.html
Findlay.
15th Jun 2020, 12:39 PM #18Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
This is the only picture I have of the one from my old one. You could try PM’ing Lamestlama he bought it from me, and may be able to assist further.
The AC attaches on the lugs sticking up, the rectified DC goes out on the plates marked +/-
The polarity of the DC will be relative to which way you put the AC into it. Check it with a digital meter without the DC leads attached.
15th Jun 2020, 09:14 PM #19
15th Jun 2020, 09:18 PM #20Cheers, Joe
15th Jun 2020, 10:01 PM #21Most Valued Member
- Mar 2011
- 1,555
15th Jun 2020, 11:28 PM #22
Hi Johhny 808
We have a great bunch of members who are always ready to help a fellow member.
There plenty to look at by going to FORUM in the left top CNR and click FORUM HOME.
The page brought up scrolls down and shows the help pages and Sub Forum interests. Please read our TOUs Terms of Use at the top.
Don't forget to check out the sub forum and the Stickies with helpful information about the help pages and/or forums.
Welcome to our Forums
Unimig or Bossweld stick machine
By asdfghjkl in forum WELDINGReplies: 3Last Post: 22nd Aug 2018, 08:31 PM -
Bossweld.
By onanonanon in forum WELDINGReplies: 19Last Post: 27th Apr 2018, 11:27 AM -
Bossweld (Bunnings) Welder?
By jack620 in forum WELDINGReplies: 35Last Post: 11th Nov 2017, 05:25 PM -
Welders
By alesandro in forum METALWORK GENERALReplies: 2Last Post: 11th Dec 2012, 07:22 PM -
4 in 1 tig welders
By WelderMick in forum WELDINGReplies: 9Last Post: 5th Apr 2010, 01:17 PM
