Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Budget Welders
  1. #16
    Aug 2009
    Sydney, NSW, Australia
    1,836
    Check out this video bloke is using a 2500w generator it appeared to me while i was watching it on my mobile he was welding around the 80 to 100amps
    https://www.youtube.com/watch?v=jFhsY5AIyNU
    another video off a 1000w generator
    https://www.youtube.com/watch?v=NILU9tJ6sGY
  2. #17
    Dec 2018
    NSW
    586
    Look at the welder data plate. Or even the machine's destruction manual tech page.
    It will have a lot of 'gobbledegook' on it, but the thing you'll be interested in is the voltage tolerance. Usually 240V +/- 15% or similar.
    Then toddle off to an online voltage drop calculator.
    Plug in cable Cross sectional area (CSA, eg 2.5mm2), ambient temp, some will also give info for single core, multi core, or bundled cables.
    This will give you an idea of how many usable volts you'll have on the end of your extension lead.
    If Voltage drop is greater than your lower acceptable voltage of the machine (ie 240V -15%, or 204V in this example), then you'll be pushing the proverbial uphill to get a weld. Welders are gearboxes for power, so there is no free lunch.
  3. #18
    Jun 2010
    Canberra
    1,322
    I'm using a 10m long x 2.5mm cored extension lead on a 15A GPO for my welder without any problems.
    Did you buy that or roll your own? Every ext lead I've looked at in the shops has maxed out at 1.5mm2.
    As I've mentioned before, I have a couple of custom ext leads made up from old bore pump orange circ cable, where I've doubled up the neutral, active or both depending on the no. of cores. I think one is 4mm2 3C+E and the other 2.5mm 4C+E.
  1. Budget tig welder: what is the two pin socket?
    By StrayAlien in forum WELDING
    Last Post: 19th Jul 2020, 10:18 PM
  2. Which budget AC TIG?
    By mark86 in forum WELDING
    Last Post: 18th Jul 2019, 10:45 AM
  3. Replies: 12
    Last Post: 22nd Feb 2019, 05:54 PM
  4. Replies: 3
    Last Post: 9th May 2013, 08:01 AM
  5. $150 budget to get an arc werlder
    By Gags_17 in forum METALWORK GENERAL
    Last Post: 12th Apr 2007, 11:26 PM
