Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
  1. #16
    Aug 2011
    4,779
    Jack, is that a Tig weld on stainless?
  2. #17
    Jun 2007
    Vic
    48
    544
    Hi Simon, That is mild steel. I find that SS will require a little less amp as it doesn't dissipate heat as well and it will blow through, that is on thin sheet anyway and I don't think it matters as much on thick material like that?
    Regards,
    Trong
  3. #18
    Jun 2007
    Vic
    48
    544
    I used the old SIP arc welder for my first tig last year, scratch start and remote gas hose with a tiny knob on the torch handle where you control the gas with the knob and the hose connects directly to the regulator at the bottle. The tungsten gets contaminated quite quick and requires re-sharpen all the time. Also the only way to finish off the weld is to move the torch away from the work, it gets the job done but quite messy at the end as the "last puddle" is not shielded by the argon and as you move a way, there is an arc that follows especially on higher amp.
    Regards,
    Trong
    PS: this on not the first weld on that tig, I probably went through about 1/2 of the E bottle by that time.
  1. WIA Inverter MMA welder
    By Gavin Newman in forum WELDING
    Last Post: 23rd Jun 2015, 11:41 AM
  2. 'New' inverter welder
    By jhovel in forum WELDING
    Last Post: 4th Mar 2013, 04:34 PM
  3. Inverter mig welder
    By dubman in forum WELDING
    Last Post: 30th Oct 2011, 09:41 PM
  4. Inverter welder help.
    By BLKWDW in forum WELDING
    Last Post: 18th Feb 2011, 10:21 PM
  5. Inverter Welder
    By Just George in forum WELDING
    Last Post: 18th Jan 2006, 09:00 AM
