Results 16 to 18 of 18
13th Aug 2019, 10:22 PM #16Most Valued Member
Jack, is that a Tig weld on stainless?
13th Aug 2019, 11:24 PM #17Golden Member
- Vic
- 48
- 544
Hi Simon, That is mild steel. I find that SS will require a little less amp as it doesn't dissipate heat as well and it will blow through, that is on thin sheet anyway and I don't think it matters as much on thick material like that?
Regards,
Trong
13th Aug 2019, 11:50 PM #18Golden Member
- Vic
- 48
- 544
I used the old SIP arc welder for my first tig last year, scratch start and remote gas hose with a tiny knob on the torch handle where you control the gas with the knob and the hose connects directly to the regulator at the bottle. The tungsten gets contaminated quite quick and requires re-sharpen all the time. Also the only way to finish off the weld is to move the torch away from the work, it gets the job done but quite messy at the end as the "last puddle" is not shielded by the argon and as you move a way, there is an arc that follows especially on higher amp.
Regards,
Trong
PS: this on not the first weld on that tig, I probably went through about 1/2 of the E bottle by that time.
WIA Inverter MMA welder
By Gavin Newman in forum WELDINGReplies: 10Last Post: 23rd Jun 2015, 11:41 AM -
'New' inverter welder
By jhovel in forum WELDINGReplies: 2Last Post: 4th Mar 2013, 04:34 PM -
Inverter mig welder
By dubman in forum WELDINGReplies: 6Last Post: 30th Oct 2011, 09:41 PM -
Inverter welder help.
By BLKWDW in forum WELDINGReplies: 0Last Post: 18th Feb 2011, 10:21 PM -
Inverter Welder
By Just George in forum WELDINGReplies: 10Last Post: 18th Jan 2006, 09:00 AM
