Results 1 to 4 of 4
30th Jun 2019, 01:39 PM #1New Member
- Apr 2004
- 4
Welding aluminium- weld building up...
I'm practicing welding aluminium (I did a search but couldn't find a specific answer, sorry) and sometimes I get it, sometimes I don't- hence the need to practice! I am using a spool gun with argon on a cigweld 185. At the moment I am practicing on 3mm square tube (rounded edge) and the weld seems to "pile up"- coming up in lumps. I've tried increasing and decreasing both amps and feed. Any ideas?
Marksilkwood
30th Jun 2019, 03:01 PM #2Most Valued Member
Without pictures makes it hard to recommend, as it could be a multitude of things. I'd say at a guess, that it could be your speed, not wire but your movement!!!
A suggestion, is to cut across your weld to see what your penetration is like.
HTH
30th Jun 2019, 03:32 PM #3New Member
- Apr 2004
- 4
Thanks Kryn, just tried cutting through, penetration looks good. I'v managed a couple of decent welds this afternoon, but inconsistent. I guess that means it's more me than the settings. I'll try varying speed and see.
Marksilkwood
30th Jun 2019, 05:49 PM #4Most Valued Member
As your welds are inconsistent, then the only cure is practice, and more practice. If you're only welding occasionally, next time you go to weld, you'll need to spend a bit of time getting the "feel" again. If I've been off the tools a month or so, it takes me a couple of hours to get it right, and I've been welding for 50+ years, so don't feel too bad about it.
Welding long aluminium planks together - boat building
By WelderMick in forum WELDINGReplies: 29Last Post: 4th Mar 2019, 02:20 PM -
Building a Aluminium I Beam Trailer
By gazza2009au in forum TRAILERS & OTHER FABRICATED STUFFReplies: 58Last Post: 30th Mar 2015, 11:45 PM -
Tig Weld Aluminium/Alloy: Melbourne
By jackaroo in forum WELDINGReplies: 3Last Post: 17th Feb 2015, 12:35 PM -
whats the easiest way to weld aluminium?
By bobsreturn2003 in forum WELDINGReplies: 13Last Post: 2nd Oct 2014, 01:55 AM -
How do I TIG Weld 1mm Aluminium
By Watts2759 in forum WELDINGReplies: 23Last Post: 23rd Aug 2011, 09:28 PM
