Results 1 to 11 of 11
21st Jun 2019, 03:45 PM #1Novice
- Jan 2011
- 21
TIG for heating and bending metal?
Hi. I've seen a couple of videos in which the operator uses TIG to heat and bend metal. My question is whether this is a practical application for TIG - i.e. are TIG machines designed / suitable for this type of work? Whilst TIG might be capable of such work, I was wondering whether it would place stress on the unit or what other limitations / wear and tear / concerns might be. I know oxy would be preferred but do wonder if TIG might offer opportunities for some simple heat and bend work. cheers
21st Jun 2019, 07:56 PM #2Diamond Member
- Jun 2010
- Canberra
- 1,322
I've thought about using TIG to heat up stuck bolts with the idea that the expansion then contraction as it cools would help it break loose, but hadn't thought about using it to heat in order to bend...
I'm sure it'd do no harm to the welder, the only thing that comes to mind is that the torch would have to be held very close to the work in order to maintain an arc, and the area heated would be quite concentrated. But apart from that, I can't see why it wouldn't work for some applications.
21st Jun 2019, 08:44 PM #3Member
- Apr 2018
- Lismore Northern NSW
- 50
- 81
I can't see that the machine would care whether you are just heating vs welding (which is just more heating). The machines all have self protection for overheating and short circuit. Because the heating is quite focal you would need to be easy on the peddle or keep moving to avoid outright melting though.
22nd Jun 2019, 11:36 AM #4Novice
- Jan 2011
- 21
Thanks! I was wondering if it was akin to using a screw driver as a chisel
1st Aug 2019, 09:01 PM #5Senior Member
- Apr 2018
- 168
Have used a TIG to heat up copper pipe enough to melt phos copper into joints when didnt have access to oxy. Not the neatest but it worked.
20th Aug 2019, 09:43 PM #6Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,844
Rusty i done this video 3-4 years ago with my repco/mechpro dc tig to remove some snapped head bolts these bolts on outboards will generally be the worse seized bolts you'll see, just looking at them they snap
https://youtu.be/ASHyr6L64-Y
You could bend the steel using the tig but its a quiet expensive way to go about it argon is not cheap and buying the tig machine plus bottle u could buy a machine designed for cold bending, i have heated quiet a few snapped bolts and found with M6 bolt size u next next to nothing in amps you'll also only be able to heat so much material and oxy has a broader flame than a tig arc so it covers more area quickly the oxy u can use a tip for heating as not to melt the material if u try up the amps to put heat in with the tig u will likely reuin the part from the molten pool from the tig it may work if u go less amps and soak it and slowly bring up the temp but duty cycle will cost u
Just my experience and experimenting i know next to nothing but i love tig welding!
If u do buy a tig machine dont buy one like in my video the scratch start is a pisser i ruined one engine block due to the scratch start jumping and arcing on the aluminium and cratering it, buy a machine which helps with arc innitilisation or has high frequency its a world of difference to scratch start
20th Aug 2019, 10:24 PM #7Philomath in training
If you have a scratch start TIG, get yourself a small copper block to do your starts on.
21st Aug 2019, 06:59 PM #8
Tungsten grind affects arc shape to some degree. 60 degree inclusive angle will give a deep penetrating arc, but all hope is lost when you start scratch starting with it.
I'd get a MAPP torch before I wasted the argon TBH. Get you to around 2000 celsius.
21st Aug 2019, 07:13 PM #9Most Valued Member
- Aug 2009
- 1,844
One option u could also consider is making a furnace either one opening or two if u want to make a bend mid way on long pieces be a lot cheaper using LPG than Argon
22nd Aug 2019, 08:12 PM #10Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,196
23rd Aug 2019, 07:49 AM #11
Now we're talking!
Help with sheet metal bending
By ned3000 in forum METALWORK GENERALReplies: 23Last Post: 19th May 2019, 12:37 AM -
Metal Heating options Mapps kits any good?
By joez in forum GENERAL DISCUSSION / OFF TOPICReplies: 9Last Post: 29th Apr 2018, 01:32 PM -
Question on Metal Bending
By kyunhae in forum METALWORK GENERALReplies: 13Last Post: 10th Jun 2017, 05:02 PM -
Bending metal rod up to 3/4 inch
By Tiger in forum METALWORK GENERALReplies: 15Last Post: 17th Apr 2015, 10:11 AM -
Heating, Bending,... and Breaking a Steel Rod (Where did I go wrong?...)
By Batpig in forum METALWORK GENERALReplies: 9Last Post: 5th May 2009, 07:48 AM
