Results 1 to 6 of 6
Thread: New Machine What would you pick?
31st May 2019, 09:17 PM #1New Member
- May 2019
- 1
Looking at new machine stuck on these two machines!
1 - Cigweld WeldSkill 250
2- BOC Smootharc Advance II MIG 250C Welder
What would you pick? both are suitable for our use general fabrication.
Any suggestions?
31st May 2019, 11:41 PM #2Most Valued Member
Hi Tiny and WELCOME to a TOP FORUM.
I have the weldskil 250 at home and we also have one where I work. Make sure you get the remote wire feeder, I have the 8metre one and the longest possible for the gun from memory mine is about 4 metres.
I've always found that no matter what length gun cable you have it's never long enough!!
If you're going to be welding in narrow confined spaces, not yourself, but the nozzle, get the narrower one. We quite often are required to weld in a space 30mm wide X 75mm long, (a block to support a pulley), and find it's quite hard to get the larger nozzle in to weld successfully, usually end up going in from each side to the centre.
My unit is about 15 years old and hasn't given me any trouble. I think the later model units can have the remote wire feeder unplugged from the main welder and the gun cable plugged in, there is the possibility that a switch may need to be flicked so that it works dirrect or remote. Mine is set as remote only as it's an earlier model, but the one at work has the remote switching I think??
This is a handy arrangement for doing bench work, as there have been times that I've pulled on my gun cable without thinking, and had the remote assembly come off the top of the welder, done the same at work also.
Hope This Helps,
1st Jun 2019, 12:52 PM #3Senior Member
- Dec 2010
- Syd
- 492
I think with everything Chinese now, from the "domestic" suppliers, probably luck of the draw and not much difference. Don't know about the CIG machine, but have that 250C as one mig, touchwood, no problems over 2 or 3 years other than a yahoo running over the torch and earth clamp with a forklift! The plug is 15A, which might be a pain if doing off-site jobs.
1st Jun 2019, 03:55 PM #4Pink 10EE owner
- 6,218
One thing to be aware of is you can not pull 250 amps out of these welders unless you at a later date install an upgraded input lead.
I have a 250 amp transmig and as the instruction manual says, for 250 amp output you need at lest a 4mm inlet cord, and no doubt a 20 or 32 amp socket as well.
I have not upgraded mine, but frequently melt 15 amp sockets and click out the C curve 20 amp circuit breaker fitted to the socket. I have never clicked out the thermal overload on the welder though.
These transformer welders are only around 50% efficient. But last for a long time as they are very robust. The inverter welders are much more efficient but I have heard of plenty of dead ones.Gold, the colour of choice for the discerning person.
1st Jun 2019, 05:22 PM #5Pink 10EE owner
- 6,218
On second thoughts, thinking I may have been wrong in the statement above where I said you can not draw 250 amps with the 15 amp plug, I tested it with my clamp on amp meter.
Of course it is CV so the amps constantly vary but it will put out 250 amps if you keep the stickout short. The lead gets warm quick though.Gold, the colour of choice for the discerning person.
2nd Jun 2019, 11:44 AM #6Diamond Member
- Aug 2006
- 1,106
Most users will never have a need to go anywhere near 250 Amps, it's all about the duty cycle
The Weldskill 250 would be the most reliable machine of the two due to being transformer based, not a lot that can go wrong with them.
Lathe pick up
By argeng in forum METALWORK GENERALReplies: 4Last Post: 21st May 2019, 03:30 PM -
Anyone around Newcastle able to do a (pay) pick up and send?
By Michael G in forum GENERAL DISCUSSION / OFF TOPICReplies: 6Last Post: 25th Oct 2017, 01:59 PM -
Grays Auction pick-up Sydney
By Theberylbloke in forum METALWORK GENERALReplies: 1Last Post: 8th Mar 2016, 08:04 AM -
Help me pick a new MIG
By new_guy90 in forum WELDINGReplies: 13Last Post: 9th May 2011, 08:25 PM -
Shearline lathe pick up
By rodent in forum METALWORK GENERALReplies: 8Last Post: 12th Oct 2010, 09:59 PM
