Results 16 to 24 of 24
Thread: Aldi Plasma cutter
13th Sep 2019, 08:38 AM #16Philomath in training
13th Sep 2019, 09:11 AM #17
13th Sep 2019, 08:24 PM #18Diamond Member
- Jun 2010
- Canberra
- 1,322
I always use a straight edge, but I still find if I'm in an awkward position, I can wander off the edge without being aware of it.
My cheap-arsed CUT 40 machine is fine with having the tip dragged along the surface, but I notice some more expensive units require a gap, and typically provide an attachment to maintain the spacing. Haven't worked out what's different with these machines.
18th Sep 2019, 10:04 PM #19Member
- Feb 2012
- 67
I invested in a Tanjant straight-line guide and a circle guide, not cheap but good quality gear that's made in Melbourne & and sold world wide. I've got a MetalMaster 215 TIG/Plasma machine so I just added the insert that fits this torch. I tend to use it a lot for sheet metal cutting, beautiful clean cut as I can set cutting angles and height. Handy too for doing bevel cuts for thicker steel where multi-pass welding is required. The Tanjants come with suction pads as well the standard magnets so I can use them on stainless, aluminium etc where magnets don't work. I soon recovered the initial purchase cost in speed and accuracy.
30th Nov 2019, 10:13 PM #20Most Valued Member
- 2,672
Been using the Aldi cutter again today. Had to cut some old brackets off my yard crane and fan new ones to fit a different steering box.
A few layers of paint etc. Cut it OK, but struggles in the thicker radiused corner of 6mm angle.
This 1.6mm painted sheet was like butter (freehand).
Reasonably clean cut on 6mm
21st Mar 2021, 05:30 PM #21Shedaholic
- Mar 2004
- Chapel Hill (Brisbane)
- 53
Anyone know what the thread on the torch is?
I have one of these (and I've cut 12mm steel with it, though it was rough as guts). Does fine in smaller stuff.
I ordered a straight handpiece to convert to CNC, but the thread is not a match, though very close. Anyone know what the thread on the workzone is (where the air hose joins the torch, inside the torch handle)?
The IEEE has monitored this posting and affirms that no energy was created or destroyed during its composition or transmission.
21st Mar 2021, 07:57 PM #22
G,day Farmer John
Welcome to the MetalWork Forums
To help you explore the other areas of our forum here's a guide on to to navigate our Forum and find all the interesting places.
Goto the FORUM box in the top left hand cnr of the page and click the down arrow. This will bring up a pull down menu that has Forum Home at the top
Click Forum Home which will present a scroll down page.
Our rules,the Terms of Service are right at the top ,we encourage you to read them.
Below that are all the various areas and sub forums that make up out MetalWork forums.
Plasma Cutter
You are a farmer. Would you buy your tractor from a grocery shop?
For me its the same sort of argument with metal working equipment.
If I purchase a machine I expect a longevity from it and the availability of spare parts. I may be wrong but would not expect it from Aldi.
If the pricing is so good to enable it to be a throw away unit, it might be Ok, given that that cuts shown are comparable with an oxy acetylene plant.
Welcome
21st Mar 2021, 08:56 PM #23Senior Member
- Oct 2015
- melbourne
- 473
May have missed the special. Farmer john's original post was nigh on 2 years ago... 😁
21st Mar 2021, 10:14 PM #24
Ah sheet! I hate that
Plasma cutter
By clive hugh in forum WELDINGReplies: 14Last Post: 2nd Nov 2015, 11:43 PM -
Plasma Cutter help
By Swarfmaker1 in forum WELDINGReplies: 12Last Post: 11th Jun 2015, 09:33 PM -
CNC Plasma Cutter.
By the_duke in forum METALWORK GENERALReplies: 2Last Post: 12th Jan 2010, 01:32 AM -
Plasma Cutter
By Dingo Dog in forum WELDINGReplies: 2Last Post: 8th Sep 2008, 07:05 PM -
Plasma cutter
By Ironstine in forum WELDINGReplies: 2Last Post: 23rd Feb 2008, 01:25 AM
