Results 1 to 15 of 52
27th Apr 2016, 09:46 PM #1
Show us your weld table jigs,fixtures, clamps and hold downs
In the General Metal forum Petip posted a little ripper weld table made from a lathe faceplate. The slots in it facilitate some ideal opportunities for all sorts of weld tooling goodies
It prompted me to think about the different jigs, fixtures, clamps, hold downs and other clever doo hickeys we either have and use on the tables or would like to buy or make.
Lets have exchanges of ideas ,opinions and especially pics of what you have or what you would like to have on your welding table.
Here's a few I have or would like .
tig C Cl Hold down.jpgtig jig vise grips.jpgF23T5TF1SRERF7G2EC.MEDIUM.jpgHelping Hands.jpg
lets see your ideas
27th Apr 2016, 10:54 PM #2
Best "jig" I've ever bought is the 2m x 1m Stronghand table and assorted tooling, much better than crawling around on the concrete floor. It's easy to make your own fittings for the table using 16mm round for the pins. It also gets use as a set-up table for kart chassis when checking and measuring for accident damage.
One of the handiest things I've made to assist in setting up is the 3rd-hand idea borrowed from Jody's tips and tricks videos. Just a couple of large ball bearing balls, a bit of scrap and some silicon bronze at the contact points.
Other gadgets are a couple of knackered drill press vices used to hold odd shape parts on the table and an assortment of scrap aluminium chunks to use as chill blocks when welding stainless. Judiciously used to back welds they can also remove the need to back-purge in some circumstances.
When setting up work on the floor the Record 90 degree clamps are invaluable. They were a reasonable cost when I started buying them 40 years ago but are not cheap now. If you can pick some up second hand they are very robust and well worth acquiring.
I also have a 4' diameter lathe face plate from the now defunct Perry Engineering works in Adelaide. At 1" thick it makes a brilliant welding table. As far as I can recall it cost me a dozen long-necks 30 odd years ago. Transporting it in the boot of my EH Holden was an interesting exercise to say the least.
20151230_120604_resized.jpgIMG_2988-1.jpg20150726_141142_resized.jpg20151227_123820_resized_1.jpg
27th Apr 2016, 11:00 PM #3Member: Blue and white apron brigade
- 7,182
I keep meaning to make a few jigs similar to the ones shown by Graeme above but still haven't hit on a design that gives me the greatest flexibility.
My welding table is small (600 x 900mm) as I mainly do small things and it fits under my fume hood/extractor which is one of the best things I did in my shed.
The table has a quickly removable 6"" offset vice and no fixed top,
If required I can remove the vice completely, and/or, lay and clamp various sheets and flat bars on top in positions that suit what I'm doing.
My selections of top are
- full size (900 x 600 mm) sheets of 6 mm steel or Al.
- half size (425 x 600 mm) 6 mm steel and Al, allows me to leave a 100 mm gap in the middle
- various sizes of 6, 8 and 10 mm x 100 and 150 mm steel bars.
This was not a deliberate upfront strategy but one that has evolved over time and I realise this system is not for everyone but it works for me.
Mostly I have the 2 half size sheets and the vice on the table.
There are times when I would like a bigger table but its not that often - besides I have no more room to put one.
28th Apr 2016, 01:12 AM #4China
- Dec 2005
- South Australia
- 1,656
If i showed you my welding table you would all be doubled up laughing
28th Apr 2016, 10:57 AM #5Member: Blue and white apron brigade
- 7,182
Go on give us a laugh.
Sounds like my WW bench for 20 years, a plywood door on two cardboard boxes for a while.
I eventually did up grade to two sagging home made trestles I found during council pick up week.
In 2006 I found the WW forums and that inspired make something I could at least put a piece of 4 x 2" on without it moving.
28th Apr 2016, 06:41 PM #6China
- Dec 2005
- South Australia
- 1,656
I will doing some welding on the week end all going to plan I will take some pics, but remember you asked for it
28th Apr 2016, 07:32 PM #7
I think this thread is a good idea. I really enjoy visiting other blokes sheds to see how they do what they do and what they use to do it. Many a time I have seen things that are sooooo simple but never would they have come out of my brain. I think we all need different types of stimuli to keep us going
Just do it!
Kind regards Rod
29th Apr 2016, 02:17 PM #8
Some more pics for you blokes.
These are things I have fabbed up
No. 1 An angle section square made to align sections for tacking.-Drop in Sq cut sections and clamp up & tack.
No. 2 A pair of vee blocks-for tacking rod and keeping alignment. Also handy in the horizontal b saw
No. 3 A positioner from a tow ball that takes extensions and attachments.
No. 4 The extension and adjuster that attach to the positioner via a 12mm connector nut.
No. 5 The face of the sliding clamp seen in pic 4 - rotatable.
Angle section Square.jpgVee blocks from angle section.jpgWeld postioner from towball.JPGadjuster different view.jpgSliding clamp on rating frame.jpg
29th Apr 2016, 03:25 PM #9
Grahame....those few jigs look to be extremely handy. Especially the towball set up, can you show us a little more of how it moves and locks into position? Do we have your permission to duplicate some for our own projects? (Industrial espionage at its best )
Just do it!
Kind regards Rod
29th Apr 2016, 05:04 PM #10
Anybody who wishes to use anything I post is more than welcome to do so. Anyway, I pinched the basic idea myself as it was originally a design for positioning wood carvers blocks during carving.Its just been tweaked for my purposes.
You will need a lathe to make the tool.The basic idea is that the towball fits in a pipe sized somewhere near towball OD. The tow ball is trapped between two shaped ( radiused ) washers (for want of a better word) The 2 washers are turned on one of their sides to suit the radius of the ball.
TIP try to keep the washers spread near to the neck diameter spacing of the towball, but spread enough to allow the neck to swivel down to horizontal.
The top washer (slotted to pass the swing travel of the towball neck as is the pipe ) is fixed by tacking and the bottom washer floats free under the towball. The floating washer is compressed against the towball with a 10mm threaded rod passing through a tapped hole in a base plate step turned to fit into the pipe and tack welded. The threaded rod ( just cheap allthread ) has a Tee handle welded on. Shape the end of the rod as a half ball shape-it reduces friction and makes for easy turning of the handle.
A bracket is welded to the pipe and the appropriate bench clamp or fitting made up to suit.
The towball has its neck original diameter reduced a bit, in the lathe. I welded on a 10 mm joiner nut to take attachments. I did originally not make the slot in the pipe deep enough and consequently the travel was only about 80 degrees instead of the intended 90 degrees. It only was fixed when I painted it. Thats why I tack jobs as its far easier to go back for adjustments.
Sorry about the photos as they don't show the internals,but I trust the explanation above is clear.
Theres no drawings but I believe there a chap on homemade tools that can design such things for us
WP_20160429_15_28_00_Smart.jpgWP_20160429_15_27_37_Smart.jpgWP_20160429_15_26_55_Smart.jpgWP_20160429_15_26_04_Smart.jpg
29th Apr 2016, 06:05 PM #11Banned
- Feb 2015
- Oz
- 73
- 459
My welding bench is quite small, topped with 700mm x 800mm 1/4" thick stainless top, tacked to a 50mm RHS framework underneath it's reasonably flat. I did want a larger one of course but the cost of a decent size steel plate was more than I was willing to spend so I added to it with a 4' long wooden extension with a formboard top, the top being level with the stainless top. I spotted the stainless plate in a scrap metal yard in Maryborough quite a few years ago, he only wanted $20 for it so I grabbed it before he changed his mind.
Formboard is quite flat and works quite well for setting up, problem is the surface does get burnt and marks quite easily. The wood section slides in to supports welded to the steel bench and is locked in place by a couple of pins. This bench does double duty for woodwork, metalwork and whatever else I need it for. If I ever come across a cheap, larger piece of steel I'll replace it, but for now this'll do.
I also added a smaller section on the lathe side for use when when turning, this section is supported on tubes that slide into the RHS under the stainless plate and isn't level so is removed when needed.
I had put aside some bits and pieces to construct some of the gizmos pictured in this thread, but it's now beyond me, hopefully things will improve and one day I can finish them off.
29th Apr 2016, 08:27 PM #12
Well you know whats going to have to happen now.....got to cut some steel and machine steel then weld steel......more fun
Just do it!
Kind regards Rod
30th Apr 2016, 01:58 AM #13Most Valued Member
- 5,942
30th Apr 2016, 07:55 AM #14Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Hi Grahame
I just have to say I love the tow ball swivel mount.
One of the simplest and handiest things I have seen in a long time
Many thanks.
Phil
30th Apr 2016, 10:14 AM #15Banned
- Feb 2015
- Oz
- 73
- 459
Clean as.
That would be my shed, super clean most of the time. Can't use a broom anymoe so bought a variable speed, cordless blower, these things are great, no dust and it gets in to all the places a broom can't, should have bought one years ago. Great for cleaning the lathe too. Told the wife it was for her to use in the garden - she's happy!
How would you hold this?
By andrew_mx83 in forum METALWORK GENERALReplies: 15Last Post: 8th Jan 2014, 03:49 PM -
Gray's auction in Carrum Downs, Victoria
By jhovel in forum METALWORK GENERALReplies: 2Last Post: 15th Feb 2013, 11:10 PM -
Carrum Downs Pickup
By markgray in forum METALWORK GENERALReplies: 34Last Post: 16th Oct 2012, 09:28 PM -
Rotary Fixtures for Shapers
By Bryan in forum METALWORK GENERALReplies: 6Last Post: 14th Dec 2010, 05:32 PM -
How to hold a rod
By phelum in forum WELDINGReplies: 12Last Post: 1st Apr 2008, 02:14 PM
