Results 1 to 10 of 10
3rd Mar 2016, 04:04 PM #1
Welding out on site ? ? Generator? My Mig
Hi ,
Ive got an older , 8 to10 Years old, BOC 250 C Mig welder .
I will be needing to weld out in the paddocks on a farm . Im thinking of a roof over 2 x 40' shipping containers with a 8 Meter space in between them .
Carting a Mig and bottle around in the ute with a generator will be my first choice but that depends on the generator I will need .
If its to big I may go back and buy a smaller arc welder , a CIG 170 or Boc 170 and a generator for that and the other tools I want to run while doing this work. Cut off saw drills and angle grinders .
so question is , what size generator for running the 250c Boc Mig .
This is a later machine but the specs should be the same ?
BOC Smootharc Advance II MIG 250C Welder | BOC Australia
I rang BOC and was played an earfull off adds and music while being placed on hold, and the nice girl got back to me and said 30 to 40 KVA ?? sounds way to big or is she right ?
I saw a post here on a generator for the 170 arc welders ,and I think someone here said 7 KVA . Id have to go check .is that right ?
Thanks Rob
3rd Mar 2016, 04:52 PM #2Pink 10EE owner
- 6,218
I run my 250 transmig off a 6.5kva generator. Of course that is just at about 2/3rd of flat out setting. It would not run it flat out, need 12KVA for that according to the plate on the welder.
So an 8kva would do what you want easily.
Not sure what drugs they were on to say 30 to 40 KVA, unless they were meaning a 3 phase generator which each single 240V outputs (it would have three of them) is usually only 1/3rd each of the total three phase output.Gold, the colour of choice for the discerning person.
3rd Mar 2016, 07:10 PM #3Senior Member
- Apr 2008
- 269
I bought a 5 kva get set to run a 140amp welder. Sales bloke in Karratha assured me that it would easily run the welder. (wrong).
Gen set on full noise and using the smallest electrodes on the stick welder, barely able to strike an arc. Might be different these days if you use an inverter welder on that size Gen set, certainly not big enough for the old Transarc 140.
DD
3rd Mar 2016, 08:52 PM #4Most Valued Member
- Sep 2010
- Lebrina
- 1,915
Sounds like you have experienced the same lack of knowledge from the BOC muppets that I have.
The 250C has an inbuilt wire feed I believe. That in itself could be a bit of an issue if you are working off a ladder when building your roof. You may need to look at self shielded wire if there is too much breeze blowing.
As others have correctly said, it will take a fair size generator to run your welder at full noise, but at more realistic amperages, an 8kVa will probably be adequate.
To be honest, I don't usually picture mig welders as site machines, they can do the job provided you can address the portability and wind issues.
3rd Mar 2016, 08:59 PM #5Diamond Member
- Jun 2010
- Canberra
- 1,322
I once tried my little BOC Smootharc 130 stick machine off a cheap-arsed Bunnings 2kVA genny (which, despite assuming it'd be a cheap POS, has proved to be an excellent machine - starts every time first pull and just runs). With a very careful striking technique (any sticking would kill the genny), I was just able to run a 2.5mm rod at about 80A from very dim memory. Which wasn't that useful for what I needed to do at the time, but may get me out of trouble at some point in the future.
4th Mar 2016, 10:32 PM #6
Looking into it a bit more , some of those generators at 8 to 10 KVA Ive seen are heavy 5 to 600 KG . It looks like the smart way to do what I want is just to weld the brackets that tie the roof to the containers edge and weld any thing else up on the ground and assemble and bolt from there rather than welding up higher. Just like shed roofs are done .
What is a good way to go with site work ? just a 170 amp arc and generator?
Or one of those arc , mig tig packs and generator ? are they the inverter ones ?
Rob
5th Mar 2016, 07:07 AM #7Philomath in training
I've seen welders on site with big generator combinations (welder integrated into the set up) and with the small lunchbox inverters if power is on site. Can's say that I've ever seen someone arrive with a separate genny and plug a welder in. It is suggested that my 200A inverter needs a minimum generator of 6kVa, so as you have said, you are looking at a heavy box if you go the separate unit way.
5th Mar 2016, 08:43 AM #8Senior Member
- Jul 2013
- nsw
- 256
I've found a 6.5-8kva generator to power your power tools and an inverter is a good site set up.
long heavy duty leads are necessary if stretching your work distance.
allows you to run a 3.2 mm rod at good heat.
5th Mar 2016, 09:29 AM #9Pink 10EE owner
- 6,218
5th Mar 2016, 03:43 PM #10Member
- Aug 2014
- North Queensland
- 86
I have an old Lincoln 175 Weldandpower AC combination unit driven by a Lombardini single cylinder diesel. I use this for jobs away from power outlets on my 8 hectare rural residental block. Easily runs 3.2mm electrodes and ok for power tools such as grinders and drills etc. Wouldn't try powering any electronic items because 240V ac output voltage is not really stable.
These old type generator/welders should be cheap to buy. Bought mine at a farm clearance about 10 years ago.
Gerry
portable generator
By splinter56 in forum WELDINGReplies: 5Last Post: 18th Sep 2012, 08:31 PM -
Air compressor & generator box
By steran50 in forum METALWORK GENERALReplies: 8Last Post: 11th Jul 2011, 07:54 PM -
Generator for Arc Welder help
By twebb01 in forum WELDINGReplies: 6Last Post: 3rd Oct 2009, 03:41 PM -
welding info site
By Grahame Collins in forum WELDINGReplies: 4Last Post: 18th Feb 2007, 12:11 PM -
Honda Generator
By timbo123 in forum METALWORK GENERALReplies: 5Last Post: 24th Aug 2006, 12:20 AM
