Results 1 to 3 of 3
Thread: welding & cutting fluid
31st Jan 2015, 01:12 PM #1Senior Member
- Jul 2013
- nsw
- 256
what's a good way of removing cutting fluid from steel I have just drilled, before grinding and welding?
don't want to add one contaminant in order to remove another, if you know what I mean?
thinking petrol, degreaseer, acetone, detergent, thinners......
what at do you use?
meadow
31st Jan 2015, 04:38 PM #2Most Valued Member
- Sep 2010
- Lebrina
- 1,910
It depends what type of cutting fluid you have used. Soluble oil will be cleared away well enough with water for all but the most critical of applications. Beware of using paint thinners - it sends you senile apparently and I don't need anymore assistance in that area
To be honest, unless you have really lathered on the cutting lube, a wipe with a rag is good enough for most general fabrication.
If you do use a solvent, then bear in mind that solvents and welding are like cats and dogs - best not kept in the same area.
Metho will remove a lot of contaminants and is more innocuous than petrol, thinners and acetone if you really need something stronger than water.
31st Jan 2015, 04:49 PM #3Most Valued Member
- 5,942
A residue of cutting fluid will help reduce the amount of welding spatter that sticks to the job, so don't clean it to hard. There is usually enough welding heat to get rid of most impurities, it's only when doing pressure vessel work that it needs to be really clean.
Modified coolant/cutting fluid
By Ben Dono in forum METALWORK GENERALReplies: 20Last Post: 23rd Apr 2014, 10:38 AM -
Cutting Fluid Ratio
By Kidbee in forum METALWORK GENERALReplies: 2Last Post: 26th Aug 2013, 11:52 PM -
What are you guys paying for cutting fluid/coolant?
By Graziano in forum METALWORK GENERALReplies: 26Last Post: 29th May 2012, 07:11 AM -
HAFCO Cutting/Coolant Fluid
By Plushy in forum METALWORK GENERALReplies: 12Last Post: 7th May 2010, 01:51 PM
