Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
  1. #31
    Sep 2010
    Lebrina
    1,915
    Boiling in water couldn't hurt, particularly if a bit of detergent or non flammable degreaser were added. Naturally, you would want to do this outside, rather than in the good lady's kitchen.
  2. #32
    Jan 2015
    Sydney
    211
    Think ill try this, probably sand blast them too cause im going to repaint anyway. Theses other parts are more critical to get it right first time. Thanka for your help Karl.
  3. #33
    Sep 2010
    Lebrina
    1,915
    Quote Originally Posted by brendanh View Post
    If you are repainting and you know that they are steel/cast iron with no aluminium components, then hot water and caustic soda will clean them up as clean as you could want along with removing the paint. A good rinse with water afterwards and you are good to go.
    Definitely don't do this in the kitchen and wear gloves and face protection as a minimum. Don't pour it on the lawn to get rid of it either as your lawn will be an ex-lawn wherever it hits.
    Caustic will dissolve skin in high enough concentrations. You can buy it in supermarkets though
  4. #34
    Jan 2015
    Sydney
    211
    Second repair went beautifuly. No undercut and wetted in nicly.
    For thoses interested. Ac, 100amps, 80%en and 150hzs.
  5. #35
    Sep 2010
    Lebrina
    1,915
    Well done, glad it all worked out.
    I wonder if the electrodes would have worked for you on the last repair as you seem to have got the cleaning issue sorted.
    Anyway, good job, you did what you had to do to get the job done and that's what it's all about
  6. #36
    Jan 2015
    Sydney
    211
    I did wondar too, got them installed on the lathe and its all sweet now.
  7. #37
    Feb 2009
    jilliby nsw
    111
    Quote Originally Posted by gyropilot View Post
    I have repaired similar in the past by Oxy/brazing. Heated it up first in the oven (wife wasn't very impressed) then brazed it and placed it back in the oven for a slow cool. Worked fine.
    Geoff
    Brilliant idea, the oven, I will certainly bake my cast brazed repair, thank you
  1. Cast Iron Repair
    By Scott in forum WELDING
    Last Post: 18th Sep 2013, 01:42 PM
  2. Bronze welding cast iron
    Last Post: 24th Mar 2013, 07:06 AM
  3. Cast iron pot repair
    By lordnelson in forum METALWORK GENERAL
    Last Post: 12th Oct 2011, 08:36 PM
  4. Cast Iron Weld Repair
    By Woodlee in forum WELDING
    Last Post: 22nd Jun 2008, 10:13 PM
  5. Repair of Broken Cast Iron
    By Grahame Collins in forum METALWORK GENERAL
    Last Post: 11th Feb 2006, 11:35 PM
