Results 1 to 15 of 15
    Apr 2010
    Rural Victoria
    358
    Default Help with Cigweld TransTig 275 Series 2 AC/DC/HF- manual required please
    Help! I have recently moved my workshop with lots of 'help' from other people... which means I have no idea where anything is. I had the manual for my Transtig 275 on a memory stick. Despite many sessions of 'Shed Tetris', its whereabouts remain unknown.
    Specifically, I need the page with the different connections for different voltages. I need to change the input voltage from 415 to 440 volts so I can run it on the two phase in the new shed (460 volts... but according to the techies at CIG this is within the 10% supply variation).
    Any help is greatly appreciated.
    Sep 2010
    Lebrina
    1,914
    I've turned up nothing in my searches. Have you tried emailing Cigweld? Try taking the covers off your machine to have a look. Many machines have the connection diagram printed internally on the covers or nearby.
    Naturally, you will have the machine unplugged when you do this.
    It's a pity that more manufacturers aren't like Lincoln who make their manuals easily accessible online.
    Sep 2008
    N/A
    535
    You _could_ try one of the american forums, like millerwelds or weldingweb. Isn't your machine a rebadged Miller? Although for a voltage question like this they might not be much help. There's a Canadian guy on those forums called "cruizer" who repairs Millers and is forthcoming with information - he could be a likely help.
    Jan 2004
    Mackay North Qld
    6,446
    If its not in here it may be close enough
    http://www.murexwelding.co.uk/mrxcon...ionmanuals.htm
    This is from list but listed as Transtig AC/DC 275 /375 but no mention of a series 2
    Parts Manual http://www.murexwelding.co.uk/manual...C275S-375S.pdf
    Instruction Manual http://www.murexwelding.co.uk/manual...C275S-375S.pdf - Mains input selection links are on page 6
    Apr 2010
    Rural Victoria
    358
    Thanks for the help guys.
    Thanks anyway Grahame, but I don't think the Murex connections are much good, from memory the CIG unit has a different layout with various combinations of horizontal and vertical bridging bars for different input voltages. I'll have a look inside the panel (I didn't think of that TBH) failing that I'll contact CIG tomorrow.
    Apr 2010
    Rural Victoria
    358
    Quote Originally Posted by Karl Robbers View Post
    While waiting for the Bathurst track repair I went and had a look under the cover of the voltage connectors and lo and behold, there is a sticker on the inside of the cover flap.
    Thanks Karl, you are a genius! I think a bloke forgets how simple some things can be when many people and companies do their best to make everything over-complicated.
    Apr 2009
    Parkdale VIC
    17
    I have a copy of this manual around somewhere if you still want it for other information.
    Apr 2009
    Parkdale VIC
    17
    Default Transtig 275 operating manual
    Better late than never. Hope this helps
    Attached Files Attached Files
    Mar 2020
    Australia - Sydney - Blue Mountains
    45
    3
    Quote Originally Posted by romerod View Post
    Hi , just wondering you still have this manual foe the Transtig 275 handy?
    cheers Drew
    Dec 2013
    Mt Waverley Vic 3149
    81
    44
    Drew, I just clicked on the links provided in post #8 and both pdf files opened
    Bob
    Mar 2020
    45
    3
    Hi Bob, thanks very much, I'll keep trying, I must be doing something wrong as couldnt see any files,
    cheers
    Drew
    Mar 2020
    45
    3
    Thanks Bob, got them now. I had to be on the full site to see the files.
    Thanks very much,
    Drew
    Quote Originally Posted by Oldgreybeard View Post
    Bob
    Jan 2004
    Mackay North Qld
    6,446
    Iam seeing the files and have no trouble opening them up.
    The files are in .pdf.
    What do you normally do if are downloading a PDF file?
    Have you been able to download other pdf files to your computer?
    What operating system does your computer have? ? Is your machine a PC or and Apple?
    For instance on my apple iMac, I click on the link and go elsewhere and click gain to open the file.
    If you tell us what your computer brand & type and operating system is, there are probably people here who can help. With some systems what you are running does make a quite a difference.
    Dec 2021
    South Australia
    5
    Question Trantig 275, Transtig 150 Service Manual
    Hi, I was delighted to see that you had attached pdf files to your post. Unfortunately, the first file (the smaller file) seems to have pages 52 to 83 missing and of course they contain the data that I am seeking. I realise that it is a big favour that I ask at this late stage, but would it be possible to post the complete manual?
    I am actually trying to get a service manual for a Transtig 150 but it seems that model is actually the "little brother" of the Transtig 275, so I am hoping that the test data in your service manual might help me. I don't suppose you would have a service manual for the Transtig 150 would you?
    Here's hoping,
    Cliff.
  15. #15
    Dec 2021
    South Australia
    5
    Cool Transtig 150 service manual
    Quote Originally Posted by oldsilverbeard View Post
    Here's hoping,
    Cliff.
    It's funny how things happen. I no sooner finished this post and opened my emails to find that someone else who was trying to help had attached the full service manual (ex CIG) for the Transtig 150!
    So if anyone else needs a copy, I have one available.
    Cliff.
  1. CIG Transtig 180 manual and advice
    By 02howdy in forum WELDING
    Last Post: 12th Jul 2020, 04:17 PM
  2. Replies: 1
    Last Post: 20th Jul 2013, 09:25 AM
  3. Looking for manual for CIG Transtig 250
    By Vernonv in forum WELDING
    Last Post: 4th Jun 2013, 03:17 PM
  4. Capacitor for CIG Transtig 180 info required.
    By Old Croc in forum WELDING
    Last Post: 17th Mar 2013, 01:45 AM
  5. Transtig 250 EC manual wanted
    By silash77 in forum WELDING
    Last Post: 12th Nov 2012, 04:48 PM
