Results 1 to 5 of 5
Thread: Tig Erratic Arc
23rd Jun 2014, 03:19 PM #1Senior Member
- Jul 2009
- 133
Tig Erratic Arc
Hi Everyone,
I currently use a tig with a 17 torch and gas lens. Of late I notice it harder to keep the tungsten clean and when I pulled the torch apart, I found the mesh on the lens was spattered with fragments. Could this be a cause? I also notice the arc often has a greenish hue to it.
Any advice appreciated.
Alan
23rd Jun 2014, 08:10 PM #2Most Valued Member
- Sep 2010
- Lebrina
- 1,915
Something is definitely going wrong. What do you think the fragments are? What has changed in your parameters/consumables/procedure?
23rd Jun 2014, 11:44 PM #3
It will help if you tell us about the metal you were welding. Details on your machine might help too. If its old there may be leaking O rings and it may be admitting into the cover gas, which will cause problems.
Erratic arc could be from the tungsten diameter being too large. Are you welding aluminium?
I have had green arc tinge in aluminium silicon alloy in the past.
Is the metal clean? Brushing with a dedicated s steel brush for ali only is required.
24th Jun 2014, 10:44 AM #4Senior Member
- Jul 2009
- 133
Now you mention it, someone gave me a piece of what I thought was plain ally to repair a crack, but it spat and spluttered and gave way far too quickly. I landed up braising it. It may have been that..
I am getting new collets and gas lens body today so will test it out, the torch itself is only a few months old, so I doubt a leak in it atm
Alan
28th Jun 2014, 12:30 PM #5Senior Member
- Jul 2009
- 133
All confirmed, not sure what the deposit is, but after replacing it, the tungsten remains clean and my arc is as it should be. I learn every day
