Results 1 to 6 of 6
Thread: Argoshield vs CO2
19th Oct 2013, 12:34 PM #1Senior Member
- Feb 2007
- brisbane
- 245
Argoshield vs CO2
Am contemplating a move to cylinder ownership instead of renting due to my sporadic use ie I can go through a bottle in 2 months and then be 12 months or more before I need another fill. The bottle ownership seems to suit me even with the relatively high cost of fills vs BOC etc. However, I am also keen to weld ally and stainless so that means 2 bottles. The CO2 bottles seem cheaper (6.8kg) and I could then have a CO2 bottle and a straight argon bottle for ally etc. So am wondering just how much of a difference I will notice between Argoshield and CO2 when welding mild steel. I generally weld nothing less than 2mm mild and use a Unimig 250 with .9mm wire.
Craig
Brisbane
19th Oct 2013, 01:01 PM #2Golden Member
- Feb 2010
- Ballina, NSW
- 900
A few of the guys here have made the move and will probably chime in. Which argoshield version are you using now?
Here's a little comparison I've come across before: MIG Welding Gas Comparison
19th Oct 2013, 01:04 PM #3Senior Member
- Feb 2007
- brisbane
- 245
20th Oct 2013, 12:53 AM #4New Member
- Oct 2013
- Cairns
- 2
Hey.
CO2 burns at a hotter temperature than argoshield. CO2 is mainly used for structural steel welding as the fusion zone is also much larger than traditional argoshield and argoshield carries a higher risk of cold fusion (welds that haven't welded to the parent metal properly)
CO2 also lets off more fumes i found.
Here is a diagram of the fusion zones for various shielding gases:
http://3.bp.blogspot.com/_G0jtuT7hiE...gshielding.png
20th Oct 2013, 08:59 PM #5Most Valued Member
- Sep 2010
- Lebrina
- 1,915
No contest. Go the CO2 for carbon steel work. You will never regret it.
One point I would make is that if you are considering using argon for stainless, you will be disappointed. Argon will weld stainless with mig but is no match for the he correct mix.
23rd Oct 2013, 09:49 PM #6Senior Member
- Feb 2007
- brisbane
- 245
Karl
Looking at getting an AC/DC tig for ally as I have a few jobs to do. So much general negativity about spool guns put me off investing in one and then had a play with my MIG in DC Tig mode on steel and other than eating the tungsten cause I had argoshield gas and a bit of a dick around with the rod feed I actually liked it and thought I might just go to TIG for ally and stainless.
Stainless is probably my least likely to weld material although you can never day never - I just don't have the project in my head for stainless but have a zillion for ally.Cheers
Craig
Brisbane
Argoshield
By seafurymike in forum METALWORK GENERALReplies: 14Last Post: 4th Feb 2012, 11:01 AM -
Migshield vs Argoshield
By antonylord in forum WELDINGReplies: 2Last Post: 12th Apr 2011, 09:28 AM -
Can I use Argon instead of Argoshield
By 1303Steve in forum WELDINGReplies: 6Last Post: 14th Apr 2006, 10:54 AM
