Results 1 to 6 of 6
21st Jun 2013, 07:19 AM #1New Member
- Jan 2013
- Brisbane
- 1
C02 bottle and Reg from Homebrew, is it ok to use with MIG
Hi All
I am new to MIG welding and to date have used my MIG in gasless mode only as i only do the odd repair job in the garage, nothing more that 5mm steel, mostly only 1.6 to 3mm.
I have a home brew system with a CO2 bottle and was wondering if i could use the same for the mig. Regulator adjusts down to minimise the flow.
What are peoples thoughts, anything I should be aware of or problems that would occur.
21st Jun 2013, 08:24 AM #2
I currently run my MIG with homebrew CO2. You don't get quite as neat a weld as Argon/CO2 mixes, but you still get very acceptable results.
Only thing to be careful of is that your gas is 100% CO2 and not a Nitrogen(?)/CO2 mix.Cheers.
Vernon.
21st Jun 2013, 10:31 AM #3Diamond Member
- Jun 2010
- Canberra
- 1,322
The important feature of a "proper" CO2 welding regulator is the flow meter, which ensures you're using the right amount of gas. You might be able to get a flow meter by itself and add it after your regulator?
22nd Jun 2013, 02:38 PM #4Senior Member
- Oct 2003
- Sydney,Australia
- 174
You should be able to find a CO2 regulator/flow gauge from some one like Hare & Forbes for a reasonable price as they sell generic Asian-made parts, unlike some places which stick a house brand on the same item then mark it up to heck so they can say its 'Australian'. Even EBay is lilely to have them.
22nd Jun 2013, 09:28 PM #5Diamond Member
- Jun 2010
- Canberra
- 1,322
CO2 welding regulators actually aren't that easy to come by. I did find one at my local Gasweld tho, cost about $80 from memory.
23rd Jun 2013, 10:09 AM #6
I use my normal MIG regulator and made up an adapter for the cylinder. I seem to recall that there is an adapter available commercially, but I don't recall the exact details.
Cheers.
Vernon.
converting from throw away argon gas bottle to bigger bottle
By o0donny0o in forum WELDINGReplies: 6Last Post: 2nd Oct 2011, 07:13 PM
