Results 1 to 7 of 7
    Jul 2003
    sunshine coast
    45
    Default Ally gassless mig?
    As he title suggests, can 3mm and 4mm ally be welded using a gassless mig? Thanks in advance as wood is good and metal is mental. Damien.
    I'm a dancing fool! The beat goes on and I'm so wrong!!!!
    Dec 2005
    Canberra
    490
    Don't even try - it'll all end in tears. Get a TIG and buy (rather than rent) a cylinder of Argon (search the forum, there are places that will sell and refill the cylinders)
    If you must do it on the cheap, the aluminium brazing rods that you use with a butane torch might be the way to go.
    May 2013
    Gracemere
    46
    285
    No. There is no self-shielded wire available for GMAW on aluminum, therefore exterior shielding must be supplied, normally argon gas.
    Jul 2003
    sunshine coast
    45
    Thanks. Damien.
    Sep 2011
    Sydney
    59
    Have you tried arc welding ally
    There are harris electrodes which will do a reasonable job (with a bit of practice)
    For around $50.00 a packet
    Jan 2011
    Far West Wimmera
    63
    4,049
    There is flux cored wire for both aluminium and stainless but both also require the use of a shielding gas as well.
    May 2011
    Murray Bridge S Aust.
    72
    6,008
    Quote Originally Posted by dubman View Post
    I did weld some ally castings some time back using the arc welder but it had to be DC!!!!
  1. Gassless mig / Porosity
    By BigPete1 in forum WELDING
    Last Post: 10th Feb 2013, 11:47 PM
  2. MIG Welder - Gas/Gassless?
    By Blu_Rock in forum WELDING
    Last Post: 4th Dec 2011, 11:19 AM
  3. Gassless wire quality?
    By Single-phase in forum WELDING
    Last Post: 5th Jan 2011, 06:35 AM
  4. Gassless Mig Welding
    By Com_fa_ta_bull in forum WELDING
    Last Post: 7th Sep 2009, 03:02 AM
  5. When Ally aint Ally!
    Last Post: 21st Jan 2008, 11:36 PM
