Results 1 to 3 of 3
    Jul 2008
    near Warragul, Victoria
    3,811
    Default spot welding aluminium
    Hi
    Being a series 1 Land Rover nut, making up new aluminium bodywork panels is a must . But how to spot weld them as the factory did it
    Problem solved . A chap who manufactures repro bodies for Land rovers showed me a handy trick. You take a normal steel spot welder - place a couple of thin stainless steel or galv. steel squares ( say 2 " square ) , between the electrodes and the aluminium panels and hit the go button . The aluminium panels are welded as good as new . I have seen the repro bodies myself, and they look perfect
    Mike
    Jul 2008
    3,811
    Default a pic
    Hi
    I found this pic of the process
    Jul 2008
    3,811
  1. Spot welding electrodes
    Last Post: 1st Feb 2012, 06:20 PM
  2. MIG welding Aluminium
    By garfield in forum WELDING
    Last Post: 22nd Sep 2011, 10:12 PM
  3. MIG welding Aluminium
    By Marc in forum WELDING
    Last Post: 14th Apr 2010, 11:24 PM
  4. welding gas for aluminium question
    By northerncat in forum WELDING
    Last Post: 14th May 2009, 02:00 PM
  5. Aluminium Welding
    By philzero44 in forum WELDING
    Last Post: 21st Oct 2008, 08:10 PM
