Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: thin weld bead
  1. #16
    Feb 2003
    formerly from Sydney (north of The Harbour), NSW, Oz
    68
    306
    to set the barrel up to precise bore the trunnion holes deeper now for a shrink fit will require a lot of headaches to get it right
    the barrel now has a taper on it
    just my thoughts, but
    could you drill the trunnion hole all the way through into the barrel cavity, shrink fit/weld each trunnion on
    and then rebore the barrel?
    regards from Canmore
    ian
  2. #17
    Jul 2006
    Athelstone, SA 5076
    4,264
    Quote Originally Posted by ian View Post
    not by this little black duck.....its going to be a firing model cannon....0.5" calibre with black powder and all that whiz BANG stuff...umpteen million (well maybe not that many buts lots n lots) psi in the barrel with unknown forces trying to push the trunnions out sideways to the barrel uh uh! ..its one of the reasons why i wanted as much barrel as possible so that forces (expanding gases) will need to push the projectile out the front and not spend its efforts trying to get out the to the side of the barrel ...thats about where I'll be standing when I light it up
  3. #18
    Coffs Harbour
    9
    Depending on the slug and powder charge weight you could be looking at up to 5,000 PSI.
    3 projectiles in one go. Wiley Coyote style.
  4. #19
    Jul 2006
    Athelstone, SA 5076
    4,264
    Quote Originally Posted by Barterbuilt View Post
    I think you have left out a digit...
  5. #20
    Feb 2003
    68
    306
    I understand what you're saying, but by drilling holes, albeight shallow ones, to take the trunnions you've already locally weakened the barrel somewhat. I was looking for a way to return the full circumfrential strength to the barrel.
    Perhaps teh trunnions shoud be welded to teh outside of the barrell -- i.e. do away with the shallow holes
    ian
  1. SOLD: New Bead Roller
    By Greg Q in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 15th Feb 2012, 04:50 PM
