Page 1 of 2 12 LastLast
Results 1 to 15 of 19
    Aug 2002
    Lakehaven, NSW, Australia
    57
    0
    Default Welders & cut-off saw
    No, I'm not going over to the Other Side
    I'm planning on getting a small welder. I'd like to be able to fabricate frames for extension tables for the table saw, other types of workshop frames/tables etc., wood racks maybe, brackets etc. Small stuff, mostly out of 1x1 or 1x2 RHS, smallish angle, up to 5mm thick at most I would think. No car panel or sheet metal work. No Al or stainless.
    Not a lot of usage, nothing heavy duty required. I could go borrow a mate's MIG easily enough I guess - but I makes the job a pain to have to do that.
    I've done a bit of stick welding, many moons ago but used to be reasonably good at it. I can deal with metal and understand the basics at least.
    So I'm contemplating a small portable stick or MIG/gasless MIG perhaps. There's a GMC stick at Bunnies I think for around $100, or up to a CIG for $200 odd. Or maybe second hand - there always seem to be small units in hock shops, at markets etc.
    I'll probably need a cutoff saw I guess - $100 GMC maybe?
    Soooo, suggestions anyone? What's the best way to go?
    The Australian Woodworkers Database - over 3,500 Aussie Woods listed: http://www.aussiewoods.info/
    My Site: http://www.aussiewoods.info/darryl/
    Aug 2003
    Christies Beach
    59
    121
    Darryl, I briefly saw the GMC welder at Bunnies but had no time to stop and examine it. It would be advisable to check its duty cycle (usually expressed as a percentage) anything under 20% may be a limiting factor. I.E. resting the machine 10 minutes after welding for 2 !
    Maybe someone has already checked it out?
    You can't go wrong with the CIG, mine has been brilliant. Just my biased opinion
    The secret to creativity is knowing how to hide your sources.
    Albert Einstein
    Oct 2003
    Sydney,Australia
    174
    Welder-wise, if you buy a stick welder in the 10amp plug range - get one with a fan - it drastically increases the duty cycle. I have a basic CIGweld unit with a fan, & it seems to have aout the same duty cycle as my old 15amp machine, just the variable amperage is in switched increments rather than continuously variable. A 15 amp unit is only a little bit more expensive than a 10amp unit, and if you are naughty you can either put a 10amp plug on it or make a 10>15 amp converter cord - most houses are now wired with 20amp rated wire, so the socket dies before the wiring catches fire.
    I think the GMC cutoff saw will be fine, or anything with a 3 year warranty - mate of mine has not had a cutoff saw last much more than 2 years - and he buys Makita & Hitachi industrial grade tools - the gear box goes first.
    Aug 2003
    Wodonga
    59
    96
    The GMC cutoff saw is not to bad for something in this price range. I bought one about 3 years ago to build some retainer walls and cut a lot of 100mm I beam with it. It still goes well today. the trick is not to try and cut to quickly, just let the saw do the work for you.
    Jan 2004
    Over there a bit
    17
    185
    1. GMC CUtoff
    2. CIG stick
    or better yet, mig, the thin walls in the RHS is a shiiit to weld with a stick welder, but piiiis easy with a mig. For your requirements a wee little gasless, or small exchange bottle driven gas mig would be the ducks guts.
    Boring signature time again!
    Oct 2002
    Brisbane, QLD, Australia
    46
    0
    The GMC model is rated at 25% duty cycle.
    Here's my basic review - http://www.onlinetoolreviews.com/reviews/gmccen.htm
    Hope that helps.
    Woodworking Product Reviews - Over 200+ Online
    Jul 2004
    nw coast tasmania
    58
    135
    i have a cig gas/gasless mig and a cig stick and a cheap warrior cut off saw. my welds with the stick welder look like big blobs of chook poop but the migs welds look very presentable. so if ya havn't done much welding like me i'd go for the mig, i got mine (140 amp) out of the tradingpost $220 (cheap). the cut off saw ($120) is crap i should have gone the gmc platnium ,but it does the job don't try to force it just let it do the work .hope this helps
    Aug 2002
    57
    0
    Thanks guys Looks like my initial thoughts were about right. I'll pick up the GMC cutoff saw - and take it reasonably easy on it. For a welder I'll hunt for a second hand MIG or gasless MIG and failing that probably pick up a CIG stick welder. I'm reasonably comfortable I can pick up stick welding again, but MIG opens up more options I guess.
    Any other thoughts would be helpful of course.
    Jan 2001
    NSW
    14
    Default Duty Cycle
    For home use I wouldn't even bother worry about Duty Cycle. The Duty Cycle is the percentage of welding time per 5 minute blocks at maximum output current. (Its not the Workshop push-bike)
    For example: If a welder has a Max output of 140 Amps and 25% Duty Cycle you can weld for a total of 1.25 minutes at 140 Amps per 5 minute block.
    If you reduce the output Amps, the Duty Cycle increases. At 80 Amps it would be around 50%, which is quite a lot of actual welding time.
    A hint with Gasless Migs, the wire/flux will absorb moisture and effect the weld quality. So if you only use it occassionally, remove the spool and store it in an air tight container with some dessicant gel.
    Glen.
    Oct 2003
    melbourne
    68
    75
    I bought a GMC cutoff saw and have had no problems with it. I have had an arc for years but recently bought a MIG off ebay new. I run it gasless but the spatter was bad so I went to gas. Now it sometimes looks like I can weld.
    Jan 2001
    NSW
    14
    Default Welding
    Hi Glenn,
    Most TAFEs run home handy-man welding courses which go for a few weeks. Might be worth looking at.
    Glen.
    Aug 2002
    57
    0
    Picked up a GMC cutoff saw and a CIG arc welder yesterday and got to play with them this afternoon. I learnt a few things.
    The CIG is the second one up in their range. 25% duty cycle at 75amps. Fan cooled. $199 at Bunnies - good setup.
    The cutoff saw is worth the $99 it cost. The cutting disc it came with is rubbish. Worked a lot better with a decent disc on it. The clamp/mitre setup is a little crappy, but I kinda expected that.
    Main thing I learnt though is that it's a LONG time since I did any stick welding and I'm going to need a LOT of practice
    Did a bunch of test welds on some flat bar and managed to make most of them look pretty good.
    I cut the 4 sides for the frame for a new table saw side table - 40mm angle cut at 45 degrees on the corners. Cutting was interesting Trying to remember how best to measure & mark out steel for a start. The early attempts to use the GMC cutting disc left a couple of very rough cuts. As a result trying to use the magnets to hold the joint together to weld was not fun. I managed to tack it together reasonably square - though I had to break & re-do one tack weld.
    Made a mess of most of the welds from there on I'm afraid Had every type of problem there is I think Got it basically done though. I did manage to flash myself twice, but not too bad.
    Ground back all the welds and realised I still have a bunch of voids and I'd missed the outer edge of one joint completely
    The mask that comes with the welder was rubbish - but I knew that. I bought the $19 CIG helment. Not too great. Lens in the wrong place (too high). Uncomfortable. Doesn't flip up easily. Worth the $19 I guess.
    It was kinda fun to work with metal again Happy with my purchases for the money.
    Aug 2003
    Christies Beach
    59
    121
    Darryl, practice makes perfect. I had to learn not to panick or hold my breath (Scared of those fumes at first). and learn to read the weld puddle (I.E. don't feed too fast.).
    We look forward to the pics of the finished bench.
    Albert Einstein
    Jan 2001
    NSW
    14
    Default Welding
    Hi Darryl,
    Mark's right, welding takes practice. Like all good hand skills a little bit of knowledge, the right equipment and practice and you'll get there. Years and years ago, I did 2 years and night school just so I could do general welding. I certainly couldn't make a living out of it, but for stuff around the home its OK.
    One thing which may be worth a look is the type of electrodes you use. CIG/BOC make some real good "handyman" rods for their small welders. These are much easier to use then General Purpose rods. I think they are an Iron Powder rod. They cost a bit more but hey, if they do the job!!
    One other tip, using an extension lead can reduce the input current slightly, so try to move the machine closer to the power point. (My second year teacher told me that.)
    Hope this helps.
    Glen.
  15. #15
    May 2003
    Melbourne, Victoria
    49
    150
    Quote Originally Posted by Tankstand
    Don't really worry about the fumes unless you're welding gal. Then try not to breathe too much of it. I had a big day welding lots of gal and felt like crap for a couple of days afterwards. Weld outdoors or set up a fan if you're welding gal.
    I have used the most expensive rods you can buy and I have used the cheapest rubbish you can get. I'll be buggered if i can tell much difference, other than with the expensive ones, there is less spatter and it's easier to get a perfect weld.
    Wait till you get your first good dose of 'sunburn' from the welding. Cover up when you plan on doing a fair bit of welding, full sleeves and long daks.
    Dan
    Is there anything easier done than said?
    - Stacky. The bottom pub, Cobram.
