Results 1 to 8 of 8
Thread: Gas for stainless
27th Sep 2011, 12:57 PM #1
Gas for stainless
What are the issues with using argoshield light with stainless. Should I be using another gas blend?
CheersThere ain't no devil, it's just god when he's drunk!!
Tom Waits
28th Sep 2011, 07:26 PM #2Senior Member
- Dec 2010
- NINGI Qld Australia
- 68
- 208
Assuming you are talking about MIG process I think you can weld SS relatively successfully with the Argoshield light, but I think a more ideal mix is 2%CO2, 98%Argon.
I just use Argoshield myself because I refuse to pay for a 3rd bottle. Can't remember the downside of using the higher CO2 mix but it's just not as ideal as the lighter miix but still seems to weld OK.
28th Sep 2011, 07:47 PM #3
At work we have Stainshield.
I've not used argoshield light with stainless so I am of no help there.The secret to creativity is knowing how to hide your sources.
Albert Einstein
28th Sep 2011, 11:18 PM #4
Confusing stuff but I think it is best with a helium mix.
Cliff....if all you have is a hammer, everything looks like a nail...
28th Sep 2011, 11:42 PM #5Intermediate Member
- Jul 2011
- Mackay
- 37
there is a black oxidation beside the weld, that depending on what finish you want, you will have to acid clean and blend back to suit. It will do the job well though, plus you will be able to use it for any steel work you wanna do. Saves getting two cylinders. (Thats for mig process, straight argon for tig.)
29th Sep 2011, 09:33 AM #6Most Valued Member
- Sep 2010
- Lebrina
- 1,910
Almost any gas will produce a weld for sure. It takes the correct gas to produce a weld of good appearance and suitable mechanical and physical proerties. Ask yourself why you are using stainless for a given job? Corrosion resistance? Heat resistance? Appearance? You most probably will sacrifice one or more of those prorerties if you choose to go the higher CO2 pathway, (Argoshield Light). Unfortunately this compromising of the material may not be fully apparent for some extended period after you perform the work. My advice, don't mess around. Stainless is an expensive product and is far more time consuming than steel to work with generally speaking. You don't want unexpected failure down the track, think of say a weld corroding 3 months after you have installed a job somewhere or a component failing due to internal corrosion leading to injury.
I cannot think of a single reason other than emergency repair, when compromising on consumables would be a recommended practice.
I don't know what you are welding, but perhaps consider the use of ss electrodes and stick weld it if you cannot justify the extra gas, although you are obviously going to but a roll of ss wire so must be considering doing a bit of work.
29th Sep 2011, 09:49 AM #7
Thanks for the replies. Very helpful. At this stage what I am making is just a prototype. Stainless is proposed for appearance purposes and the welds will not be seen in either this or the finished good. If it works, then I will be having the welding done by a workshop geared up for stainless.
Tom Waits
29th Sep 2011, 09:59 AM #8Most Valued Member
- Sep 2010
- Lebrina
- 1,910
Stainless TIG gas consumption
By Corgan in forum WELDINGReplies: 27Last Post: 12th Sep 2011, 06:09 PM -
Stainless steel hex bar
By Sterob in forum METALWORK GENERALReplies: 7Last Post: 21st Feb 2008, 11:28 PM
