Results 1 to 8 of 8
30th May 2011, 10:59 PM #1Intermediate Member
- Sep 2010
- 26
Where to buy plate steel in north west sydney?
Hi everyone,
I have a workbench with a pine top and I was think of getting a piece of plate steel maybe 10mm thick to throw on top for welding. Anyone know where I could get a piece around 700mm x 900mm and any idea on price?
I am thinking this way as I would't not have to get a second steel bench. I think welding on the ground would a bit annoying after a while and don't know if its any good for the concrete.
I am in North West Sydney (Rouse Hill) if anyone can help.
Regards,
Rohin
30th May 2011, 11:54 PM #2Member: Blue and white apron brigade
I reckon Ally makes a better top for a welding bench. It doesn't rust and there's not much that will stick to it so stays a lot cleaner than a steel top. The one advantage of a steel top is you can weld support brackets direct onto the table if you need to but there's not much that can't be supported given sufficent clamps and bits of steel.
Also don't bank on not starting a fire by just covering the wooden top with metal. It would be safer to either replace the wooden top completely or place an airgap between the wooden and the metal tops.
31st May 2011, 06:26 AM #3Intermediate Member
- Sep 2010
- 26
Thanks Bob,
I was thinking two put a piece of tube steel under each sides of the plate giving me a gap.
Any idea where I can get some in sydney?
31st May 2011, 08:34 AM #4Member
- May 2008
- 79
Hi Rohin ,
I normally get it from Metaland they have a Penrith store. You can get pretty much anything you need and they cut to length.
Pete
31st May 2011, 10:36 AM #5Intermediate Member
- Sep 2010
- 26
Thanks Pete,
Sounds perfect. I will get down there.
31st May 2011, 10:47 AM #6Member: Blue and white apron brigade
31st May 2011, 11:19 AM #7Hammer Head
- Jan 2005
- 55
edcon steel a kings park, will sell you any size you need plus have off cuts that are cheap.
31st May 2011, 03:17 PM #8Intermediate Member
- Sep 2010
- 26
Yeah Bob, I was going to weld them, did think of the screw though!
Thanks Gaza, will try them first given they sell offcuts.
