Results 1 to 5 of 5
Thread: MIG Welding Stainless
29th Apr 2010, 11:52 PM #1
Hi,
I've got a Migatronic 180MXE which is currently setup for mild steel with BOC Argoshield Light. What do l need to do to weld stainless steel with it?
Pure Argon?
Stainless wire?
What else?
Are there various stainless wire grades depending on the parent metal grades to be joined?
Is welding stainless any different to welding mild steel? I heard that it warps more as it expands more than mild steel so suppose need to be careful of length of run.
Basically, if l can weld stainless successfully without a TIG, that will be great. l have a beer barrel project to turn it into a bbq (or something!)
30th Apr 2010, 12:40 AM #2
Argon +2% oxygen seems to be recommended for many S/steel jobs.Should be suitable for 304 or 316 stainless grades
Pure argon will be too cold I feel.
The welding procedure adopted should be one of lots of small tacks say 1 inch to 1.5" apart.
Small runs then moving to approx opposite side or diagonal opposite to balance and minimise heat inputs
30th Apr 2010, 05:37 PM #3
an appropriate BOC gas would be Stainshield. https://boc.com.au/boc_sp/downloads/...art_Poster.pdf
Have you seen the cost of a roll of stainless wire?! might put you off, did me.I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones.
Albert Einstein
30th Apr 2010, 06:08 PM #4
30th Apr 2010, 06:12 PM #5
awesome, make sure you post about your progress and maybe a few pics. My MIG is setup for steel and aluminium. I'll master ally before going on to stainless. Me going to stainless would mean 3 bottles to hire a year! $$$ Argoshield light (for steel), Pure Argon (ally) and then Stainshield for the stainless. Reckon it would cost over $400 a year.
Albert Einstein
Tig welding stainless to mild steel
By steran50 in forum WELDINGReplies: 10Last Post: 6th Feb 2010, 04:46 PM -
TIG welding mild steel with stainless filler rod?
By johnjohnmulley in forum WELDINGReplies: 22Last Post: 24th Sep 2009, 02:23 PM -
Welding thin Stainless
By pipeclay in forum WELDINGReplies: 15Last Post: 12th Jun 2009, 04:37 PM -
welding Mild steel rhs to stainless rhs
By yogie in forum WELDINGReplies: 14Last Post: 14th Jun 2008, 09:07 AM -
Stainless Steel welding
By Clinton1 in forum WELDINGReplies: 15Last Post: 6th Apr 2007, 01:58 AM
