Page 1 of 3 123 LastLast
Results 1 to 15 of 33
    Portland, VIC
    14
    Default Tig Welder Advice
    Hi all,
    I'm after some advice on a new or secondhand Tig welder. Not interested in chinese, have a budget to suit a commercial type unit.
    I have three phase but would also consider any single phase recommendations. The unit will be used for aluminium boat fabrication primarily.
    I currently use an old Transtig 250 but looking for something a little more up to date. My three phase supply is limited to 20 Amps at 415 Volts.
    As an aside is anyone interested in a Transtig 250 AC/DC with leads, foot control, regulator and a pile of bits and pieces?
    Cheers Silas
    Dec 2005
    Aus
    156
    Quote Originally Posted by silash77 View Post
    What's that mean exactly? $5000, $10000, $20000?
    Portland, VIC
    14
    Budget is 5-10K but happy to buy secondhand to get a better unit.
    Apr 2010
    60
    95
    Kemmpi or if you want to part with more $ Fronius but you will get better support from kemppi.
    Dec 2005
    Aus
    156
    Fronius MagicWave series is excellent. You'd be looking at a 2200 or 2500 with that budget if you want a new one. I think a 2200 is about $7-8k and a foot pedal is $1k.
    Kemppi are apparently also fantastic, but I've never used one. Someone here could probably comment on which models are good.
    Aug 2006
    1,106
    Are you looking for something compact ie inverter or will a larger transformer based machine be fine?
    Keep in mind you will be up for big $$$ when things go wrong with the inverters compared to transformer based.
    A lot of large fabrication places stick with transformer machines because of this. Depends on your needs though, if you need to move it around a lot the inverter might suit better.
    Mar 2008
    Australia
    74
    Default Ewm/boc
    Worth checking out the new BOC/EWM Smootharc Elite TIG 230 AC/DC rrp $5030 inc. Seriously price competitive compared with others which are closer to $7000+ (Fronius, ESAB) Competition should theoretically drop prices in response considering the falling Euro and rising Aussie dollar.
    http://www.bocworldofwelding.com.au/...230-ac-dc.html
    It appears to be a rebadged German EWM Tetrix 230 AC/DC
    http://www.ewm.de/produkte/wig/tetri...159-00502.html
    Has the same EWM 3yr warranty; 5yrs on transformers and rectifiers.
    Appears to have all the same innovations as Fronius and Kemppi have been doing for longer - active arc control, spot, one dial settings, etc.
    Programmable to run off 10A mains at reduced power and protected to not blow up if plugged in 400V. Also runs on 230V -40% +15%.
    The latest BOC catalog suggests they have dropped Kemppi in favour of EWM for their higher end range with a new range of EWM TIG torches. Also a cheaper chinese-looking model at half the price.
    Have been pondering getting an AC/DC tig for hobby welding (Al, SS, etc) for some time. The combination of German engineering and local BOC support looks pretty good.
    For boat building, I presume you are better off with water cooled + 3 phase power - models higher up the range....
    May 2009
    sydney
    183
    I bought a 240V Kemppi Mastertig 2300 with the pulse panel last year and their claim is it will run to 230 amps at 40% ed. Haven't gone there yet but every function seems to work flawlessly, with easy setup. 15kg. 15A connection, 32V MMA. Basic box with torch and leads cost around $4300 IIRC, + pulse panel+foot pedal.
    woodworm.
    Mar 2008
    Australia
    74
    Default Kemppi
    Best price I have seen in the last 12 months for Kemppi MLS2300ACX (pulse panel) is around $4700+GST.
    May 2009
    sydney
    183
    Yep, mine WITH pulse $4600...PLUS GST.
    woodworm.
    Portland, VIC
    14
    Hi all,
    Thanks for the responses. Kemppi are certainly getting good feed back. Have been looking at several of their units. Will let you know how I go.
    Cheers Silas
    May 2009
    sydney
    183
    If the BOC/EWM had been available last year when I was looking at the Kemppi I would have also considered that. You can't ignore the benefits of a 3 year warranty.
    woodworm.
    Mar 2008
    Australia
    74
    I saw Kemppi MLS2300ACX (pulse) at BOC for $4200+GST (on special). I presume they are running out Kemppi now that they have a deal to rebadge EWM machines. That price makes them a few hundred dollars cheaper than near equivalent BOC/EWM SmoothArc Elite TIG 230 AC/DC.
    Jan 2010
    wa
    22
    just won a tig $350 i think its a bargain but now the foot pedal worth $265 any one have one of these tigs.
    Pulse TIG Welder Fully Featured Welding IGBT - eBay, Welders, Welding, Industrial. (end time 28-Apr-10 21:36:05 AEST)
    I am Not Crazy I Was Tested
  15. #15
    May 2009
    sydney
    183
    Quote Originally Posted by lornety View Post
    In your case, a handbag would be more appropriate...
    woodworm.
  1. Mig Welder
    By China in forum WELDING
    Last Post: 27th Dec 2009, 10:10 PM
  2. here we go again - welder advice
    By dennford in forum WELDING
    Last Post: 4th Jul 2009, 12:04 PM
  3. MIG welder.. Should I get one ?
    By Paddy in forum WELDING
    Last Post: 8th Dec 2005, 10:26 PM
  4. OT: Welder Help
    By Jock_Jock in forum METALWORK GENERAL
    Last Post: 22nd Sep 2004, 08:25 AM
