Results 1 to 3 of 3
28th Feb 2010, 03:13 PM #1New Member
- Jan 2010
- Far north qld
- 3
Argon Regulator flowmeter - orientation.
This seems like a really dumb question, but I've searched without result - so here goes.
I have an "E" Argon cylinder from BoC. It has a side entry for the regulator.
My regulator/flowmeter when oriented "logically" with the flowmeter vertical has the connection pointing vertically down.
If I screwed it into the E bottle the flowmeter would be lying horizontal.
The obvious??? thing to do is loosen the flowmeter and rotate it 90 degrees. (then tighten it!).
Then the flowmeter would be vertical with the pressure gauge and regulator assembly lying horizontally.
Is that the right thing to do, or is there another moe appropriate solution?
Yours sheepishly.....
AlunLast edited by obrien43; 28th Feb 2010 at 03:16 PM. Reason: Clarified question.
28th Feb 2010, 05:59 PM #2
Hi
Never let it be said that I left a fellow resident of the great
FNQ in the the lurch.
Though I am beginning to think FNQ stands for flooded North Queensland.Global warning crap!, Its going back towhere it was 20 years ago.Bosses weather every weekend for a month!
As far as the flowmeter goes, if the the tube and floating ball type keep the tube vertical. If its a gauge with a radial reading needle, just suit yourself.
28th Feb 2010, 07:32 PM #3New Member
- Jan 2010
- Far north qld
- 3
Thanks Graeme,
I'll post a piccy when its connected up. The ball flowmeter will be vertical, but the regulator and pressure gauge will be "flat on their back".
Alun
Argon for MIG / TIG
By Beerbotboffin in forum WELDINGReplies: 24Last Post: 8th Aug 2011, 08:33 AM
