Results 1 to 4 of 4
Thread: Advice needed
22nd Feb 2010, 09:49 PM #1Novice
- Jan 2007
- Cleveland QLD
- 55
- 15
Advice needed
Gents
I'm currently rebuilding an old trailer, and one of the enhancements is a stock crate/cage.
I've built two ladder racks from 40mm SHS, which are designed to fit into some existing "sockets" one on each corner of the trailer box.
These sockets were made by welding 2 pieces of angle together, the problem being that the inside dimension is just less than 40mm, and the ladder racks won't fit into them.
I have run a thin-kerf friction blade down the side of one of the angles to split the socket and allow the SHS to fit.
Now of course, I have a slot in the Angle that will undoubtedly rust if left untreated.
What is the best way to fill this slot? I assume a thin piece of mild steel welded into it, or can I just run a nice wide bead along it? The slot is approximately 3mm wide.
Any suggestions greatly appreciated.
Scott
22nd Feb 2010, 10:54 PM #2danielson
- Dec 2009
- broadford
- 63
- 213
hi scanfor,i would think a plate over the top your cut would give you the most ideal repair,something around 30 x6 flat and heavily stitched.whats your welding skills like?
22nd Feb 2010, 11:35 PM #3Novice
- Jan 2007
- Cleveland QLD
- 55
- 15
My skills with MIG are OK, but they are "emerging" with my new DC stick.
Plating would be an ideal solution, thanks.
23rd Feb 2010, 06:25 AM #4Boilermaker
- Mid North Coast NSW
- 45
- 177
I'd remove the angle completely and weld in some RHS sections to suit your racks. Otherwise you'll fill a 3mm gap no worries with mig.
