Friends, I need some help.
My wife’s current hobby is making jewellery items from wire, slit and formed into round links like chain mail. These she can buy at huge expense.
I obtained 10m of painted copper winding wire for electric motors from a mate, made up a mandrel of the correct ID for the desired product, engaged backgear on the Myford and wound a perfect coil. http://www.woodworkforums.ubeaut.com...cons/icon7.gif
Then the trouble started. I needed to slit the coil along its length to produce many small rings.
I started by making a chuck mandrel that held an HSS circular slitting saw working with the coil held in a Record machine vice shimmed and set up on the cross slide. It did not work, as the clamping pressure needed to hold the coil distorted and damaged the wire.
Next I tried clamping the coil (mandrel included) in the vice, and using my jewellers saw to slit it longwise. A lot of hard work, and a very rough job was the result together with a blunt saw.
I next tried the Dremel with a cutting off disk, but this heated up the wire to the point that the coating changed colour.
Has anyone got a suggestion as to the proper method of slitting? Any other solutions?
Best wishes, Hamish.
