I started this journey with making a small wooden split pattern but couldn’t figured a good way to do my logo and the text. Sometime later I got a Aldi 3D Printer.
So I downloaded Fusion 360 and got to learning on the fly and 3D modeled my anvil with draft.
https://uploads.tapatalk-cdn.com/201...28ccf81b0a.jpg
First print using sample filament that came with the printer hence color changes as it ran out.
https://uploads.tapatalk-cdn.com/201...4d325fc192.jpg
https://uploads.tapatalk-cdn.com/201...b30f43347b.jpg
I printed a whole bunch more for economics it’s cheaper to have 8 in a mould than individually ram each one up.
Had a fixed flask dimension and had to try to work out how many I could fit into the flask and where the sprue, runners, gates etc would be.
https://uploads.tapatalk-cdn.com/201...ba400d3323.jpg
https://uploads.tapatalk-cdn.com/201...20bcc7844f.jpg
I sprayed all the prints with high build spray putty and hand sanded them all back with wet n dry paper. I didn’t want any of the print layers showing through.
https://uploads.tapatalk-cdn.com/201...03203057f2.jpg
https://uploads.tapatalk-cdn.com/201...e3f41829e6.jpg
I drew up a template for the flask and drilled the location pins.
https://uploads.tapatalk-cdn.com/201...cc6d5ed1cc.jpg
https://uploads.tapatalk-cdn.com/201...916b948547.jpg
The match plate all rammed up gives this sand mould in the flask.
https://uploads.tapatalk-cdn.com/201...44b7cad86b.jpg
After pouring in bronze.
https://uploads.tapatalk-cdn.com/201...17a26b6cba.jpg
https://uploads.tapatalk-cdn.com/201...f07a9f95a3.jpg
