Whenever I use the tangential I find after a while the cutting tool slides down in the holder. Anybody have this happen?
Never happened with my "Diamond" tool holder from Eccentric Engineering.
cheers
Piers
I have found mine has slipped while doing some projects some times. In my case I put it down to the cutting bit losing its cutting edge because the material being cut was quite hard. I have had to "lay into" the hex bolt/clamp to stop it slipping. I think in frustration I ended up using a carbide cutter in another holder to get the job done.
nope!
Hi Rod,
Use some double sided adhesive tape underneath the clamp !
I had that problem.
Here is how I fixed it.
Attachment 374144
My two capscrews and washers to hold the cutter are quite flimsy compared to many of the holding mechanisms I've seen on the web.
Bill
