2 Attachment(s)
Vessel Impacta screw drivers
I purchased a pair (JIS # 2 and JIS #3) Vessel Impacta screw drivers from Japan (on eBay) and they arrived yesterday. I've used them both yesterday and today on some very difficult, tight and rusted Philipshead and JIS screws.
I found them really excellent quality, very hard tips and great not to have to go find and use the 'regular' impact driver - which I often find difficult to line up and find space to hit or whatever.
These screwdrivers have the 'undo' function built in: you just use them as normal but when stuck, you hit the end with a hammer. The spiral cam inside will then turn the blade by 12deg per hit. So usually one or two hits is enough to loosen the screw, without changing tool.
Attachment 371613 Attachment 371614
