Help needed identifying this DC motor Specs
Hi all,
I'm in need of a replacement DC motor for a small 12VDC hydraulic pump which i plan on using as the log lifting system for my hydraulic log splitter. The pump was originally used on my hydraulic press but i burnt the motor out.
I have a smaller 24VDC motor which "may" do the job. Even running on 12V it may still generate enough pressure to lift heavy (to me) logs. The pump can produce over 3000 psi but i doubt it will need to produce anymore than maybe 500 psi, depending on the log, the ram used and the placement of the ram.
Anyway, the intended motor i have has a nameplate thag i find rather confusing.
It states 24VDC and 450W but also 4.5A max.
However 4.5A @24VDC is only 108W.
108W will definately not be enough.
Any help on watt (pun intended) the max power of this motor is @24VDC is much appreciated.
Simonhttps://uploads.tapatalk-cdn.com/201...518d03de3b.jpg
Sent from my SM-G900I using Tapatalk
