Rebuilding a Macson surface grinder
Quote:
Originally Posted by
Petip
Hi Alf
Flat belt drive
motor pulley 3.5"
spindle pulley 2.8"
Pete
Hi Pete,
Have just fired up my Macson with 'V' pulleys as advised (I got it with the spindle pulley as a 'V' so assumed it was standard) and when I fitted the grinding wheel it undid itself - nut is a RH thread and there are no markings on the home made wheel cover to suggest its correct rotation obviously with a RH thread retaining nut the wheel must rotate anticlockwise - supposed matched pair 'V' belt shows different tension on each belt although local belt supplier says there length is within 1mm. of each other? however to be fair I made the motor pulley.
What is your grinding wheel rotation please
Petip
Hi Alf
Flat belt drive
motor pulley 3.5"
spindle pulley 2.8"
Pete
Hi pete,
have just fired up my Macson with 'V' pulleys as advised when I fitted the grinding wheel it undid the nut (RH thread)
What thread is holding your wheel on , I assume it will be a LH thread and your wheel rotates anticlockwise?
please advise
