Metal lube/coolant issues
Recently I found out I might have something called Sarcoidosis which has been linked amongst other things to metal work lube coolant so I thought I would post about it here.
Its a relative rare condition with something like 10 people per 100, 000 having the disease.
It’s slightly more than this for women and less for men, with the most common ages being in the 20 to 40 year old age group.
My Sarcoidosis diagnosis is not confirmed but I have a number of the symptoms including dozens of small (2 to 8mm) nodules in my lungs, chest cavity and some in my abdomen, general fatigue, a rash on my feet, and aches and pains in my ankles and feet. Blood tests show the nodules are unlikely to be cancerous although a biopsy is required to confirm this. Sarcoidosis usually reduces lung/organ function which I don't have although my general fatigue prevents me from telling if my lung function is poor or I am just generally unfit.
The causes of Sarcoidosis are unknown. Although it is not a auto immune disease it is like an auto immune disease resulting in over active immune cells attacking some sort of bug that has entered the body and causing inflammation and then forming nodules at the inflamed sites. The inflammation become fibroid and even calcified. It can affect most organs of the body and if enough of these nodules develop it may cause organ failure. In most cases it goes away by itself but in a few cases it may even require organ transplants and a few % of sufferers can even die from it.
One cause is thought to be combustion products with poorly ventilated wood burning stoves, fireplaces etc suspected. Firefighters in general and the firefighters who were at the world trade centre collapse in particular have one of the highest incidences of it. One cause I keep thinking of is being constantly bathed in two stroke smoke from using a chainsaw in the last few year
Bugs that grow or travel in or with green wood have also been implicated hence the higher than normal incidence amongst timber millers, while cabinet and furniture makers using dry wood are much less likely to get it.
Another know cause is the bacteria that grown in coolant lube used in metal workshops and as I have spent a more time in the metal working end of my shed in the last 3 years than using a chainsaw, so I’m wondering if this might be the cause. I have always used the antibacterial lube and always over pumped it to aerate the fluid to reduce the growth of anaerobic bugs .
Anyway was just wondering if anyone else knew others that might have this.
