2 Attachment(s)
Better choice for Couplings?
Hi Guys,
I wonder if there is a better choice for couplings I can use on my machine?
The machine came with ( what I think ) are quite ridged couplings. I think they would not be very forgiving in regards to ball screw to motor misalignment ( binding )and generating noise.
Attachment 363410
I thought a better option may be this flexible type:
Attachment 363411
What do you guys think? Am I on the right track?
Any good aussie suppliers?
Need 8 mm x 8mm holes.
PS: I found some light machine oil and it seems to do the job.
Have also found a dodgy bearing and some corrosion inside the Z axis stepper, so I have ordered some bearings...(lol)
Have to run out of things to fix soon...
Corrosion is probably my fault. Water cooling lines were leaking a while before I could find a fix...doh.
