5 Attachment(s)
Richardson E39 Bench Drill Press Restoration
I picked up an old Richardson E39 drill press for $30 about a month ago, it had been lying in pieces in a shed on a rural property for many years and was pretty rusted up.
Attachment 267548 Attachment 267549
I already have an el-cheapo floor model that I got from Supa-Cheap but the quill was sloppy out of the box and far from a precision machine. The Richardson looks to have been made in the 60s and is solid as the preverbial.
The wiring was totally perished so I stripped it out (will replace with more up-to-date setup) and temporarily hooked up a plug and reassembled it. It fired up and ran OK but it needed a bit of TLC to restore it to its former glory.
Pulled it right down and wire brushed the rust off (angle grinder driven), followed by a lot of elbow grease and emery cloth... it took many hours to get it rust free... more than a bit of a wire brush that the seller reckoned it needed :)
Then on to the paintwork, first with a flap disk and more elbow grease and emery cloth.
Attachment 267550
Last weekend I welded up some tube for the stand that it will live on, you can see it in the picture above, it still needs a bit of work to finish it off, some drawers need to go in between the framework.
This weekend I got around to putting a coat of hammer finish green on the beast, black on the motor after a coat of rust converter, and got all the parts ready for reassembly.
Attachment 267551Attachment 267552
I will blacken all the nuts and bolts before I re-assemble.
6 Attachment(s)
Richardson E39 Drill Press Resoration and Stand
Finished off the Richardson today, I'm pretty happy with the end result.
Upgraded electricals, the enclosure looks like it was made for it. I've used the same type of LED light on my mill, lathe and and other drill press, good value online for about $20.
Attachment 269524 Attachment 269525 Attachment 269526
Replaced the chuck with a keyless, about 0.03mm runout after some 'fine tuning'
Attachment 269527
Stand is now finished too. Picked up the steel 3-drawer cabinet for $20 from the recyclers and made the stand to suit.
Attachment 269528 Attachment 269529
earth connection on handle side i need a picture i lost my connection
hi the other side of drill do you have a picture of the earth connection?
earth connection?
Quote:
Originally Posted by
Blu_Rock
Attachment 267550
