Interesting Lathe-Mill Combination
HI:),
I was just Browsing on Practical Machinist and came across a Link to a Dainichi Lathe-Mill Combo. It has Finished on Ebay now,but here is the Info from Ebay
DAINICHI MODEL UNIVERSAL 36A BED GAP LATHE
VERTICAL MILL MADE ON THE LFT END OF THIS UNIT
SWING OVER BED IS 20"
SWING WITH BED REMOVED 30"
INCH AND METRIC THREADING
52" CENTER TO CENTER
PASS THRU 3 JAW CHUCK
UNIT IS 3 PHASE BUT THE LATHE MOTOR HAS BEEN CHANGED TO SINGLE PHASE. JUST NEED TO BOLT A 3 PHASE MOTOR ON AND IT READY FOR 3 PHASE
VERTICAL MILL DOES HAVE SHAPING WITH A 12" STROKE
30 TAPER ON MILL
QUILL DIA. IS 3"
IT DOES HAVE FACTORY POWER TABLE FEED
I ALSO HAVE THE CENTER REST AND THE FOLLOW REST
I DID MODIFY THE BED A LITTLE TO SWING SEMI TRUCK WHEELS. IT DOES AFFECT ANYTHING ON THE LATHE . I DO HAVE THE BED GAP ITS JUST NOT PICTURED. THIS LATHE WAS BUILT TO BE PUT IN TOOL ROOMS ON SHIPS. I HAVE USED IT OFF AND ON FOR THE LAST 4 YEARS AND IT WORKS GREAT WITH VERY LITTLE WEAR. IT WAS DIRTY WHEN WE TOOK PICS IT HAS SINCE BEEN CLEANED AND READY TO GO.
There was No Bids on Ebay, but the starting Bid was $2,000.00. The Listing ended, because the Item is no longer available.
