VSD Remote Control Panel Questions
About to wire up a remote panel for my new 3 phase VSD installed on a cloned AL-960B and I would like your opinions on which controls are necessary and which - if any - are a waste of space.
There will be a single momentary pushbutton for run/start.
There will be a stop limit switch on a foot operated brake, and a locking mushroom head stop pushbutton on the panel.
There will be a two position rotary or rocker switch to select forward or reverse.
There will also be a potentiometer for speed control - do you suggest a single turn or ten turn pot? Ten turn gives finer resolution - but is it overkill?
There are two inputs for jog controls - one forward and one reverse. I am leaning towards just the forward - is their any reason to have both - or neither?
Look forward to your input. :)
