Results 1 to 4 of 4
Thread: Gear Life Chinese Lathe
14th Jun 2009, 04:10 PM #1New Member
- Apr 2009
- Redwood Pk Adelaide SA
- 7
I have recently bought a Chinese lathe from Ozmestore which is described as a 22x10". I have had a play with screwcutting etc which requires substituting various gears for the right speeds and travel. After that I put the gear train back to standard where it agrees with the feed chart on the front of the machine.
I am wondering whether this is a good idea as it means that the same gears are in use for most of the time. Has anyone had any long term experience with these machines as far as the life of the gears is concerned. Obviously I could put in other gears that drive the lead screw and that would spread the wear, but I would lose the convenience of the travel chart on the front.
I must add that I am only in to hobby use so it is not flat out all day or even close. Does anyone have any advice on any special lube for the gears. Thanks Barry
14th Jun 2009, 09:05 PM #2
From past experience, as long as the gears are set up right there should not be any problem with them and should last a long time. I cant say exactly how tight or loose they should be, but they should have a little play (gap) between the gears.
Squirrel..
14th Jun 2009, 10:23 PM #3
The traditional method of setting the clearance between the gears is to place a piece of thin paper between the gears, secure them and then wind the paper out. Works for me.
15th Jun 2009, 01:06 AM #4Most Valued Member
- 4,890
If the Gears are Metalic you could use some Heavy Gear OIl maybe a 200 grade,I use Chain Lube ( Motor Bike ) have never had a problem and its very sticky.
Boxford Lathe - Back Gear
By fluxcored in forum METALWORK GENERALReplies: 6Last Post: 6th Feb 2009, 11:09 PM -
Replacing back gear assembly on Hercus 9" lathe.
By mob in forum THE HERCUS AREAReplies: 3Last Post: 23rd Sep 2008, 11:35 PM -
Metal gear / worm gear needed
By colinshannon in forum METALWORK GENERALReplies: 14Last Post: 29th Mar 2007, 10:49 PM
