Results 1 to 7 of 7
Thread: Bernzomatic torch
14th May 2009, 12:05 PM #1Member
- Feb 2009
- Kyabram, Victoria, Australia
- 46
- 96
Bernzomatic torch
I bought myself a Berzomatic TS4000 from Thomas Warburton the other day for a very good price of $92.50 on special, and its the fatbot version with 20% more gas. Its not as hot as an oxy but its fairly hot non the less as it uses mapp gas. I just went out into the shed and heated a 5mm bolt end up and bashed it flat in a minute or 2.
I have seen the non fatboy versions selling for over $140, quite impressed and I dont need an oxy just yet. Here is a link to what I got http://bernzomatic.com/PRODUCTS/KITS...3/Default.aspx
Just thought people might like to know in case they want to get one.
Matt.
14th May 2009, 12:25 PM #2Senior Member
- Mar 2007
- Canberra
- 67
- 179
Nice one Matt. Any idea how long the cylinders last for and how much the replacement cylinders are. I've been looking at a Mapp torch for a while now but the costs of the replacement cylinders and the time they last has been a deterrent.
Peter
14th May 2009, 12:28 PM #3Member
- Feb 2009
- 46
- 96
I'm not sure, but i've heard 20 minutes. I should have a rough idea soon though i'd hope, i'm currently using it more for play than any actual job. I bought it purely cause I wanted a torch and oxy was a little to expensive to buy with nothing to do with it.
I'll get back to this thread with a time when I run out of gas.
Matt.
14th May 2009, 03:12 PM #4Most Valued Member
- Charlestown NSW
- 1,673
I know what you are saying. I've had oxy at home now for more than 20years but I'm really starting to question whether I really need it since it costs over $100/cylinder a year for rental. That was last years price. It sems to go up by $15-$20 year.
Trouble is for some jobs nothing but oxy will do the job.
bollie7
14th May 2009, 03:30 PM #5
I think it's like any tool; once you have it you find more and more work for it. I had at least one oxy set (sometimes three) from the age of about nineteen and I only let my cylinders go when I retired seven and a half years ago.
Now I discover I could really do with a small set again for small brass castings and light forging, but the rental puts me off too. Plus I don't drive any longer and nor do we own a ute any more either (for the fuel cylinder).
When will they ever get around to piping oxygen and acetylene to homes and businesses!.
I know you believe you understand what you think I wrote, but I'm not sure you realize that what you just read is not what I meant.
Regards, Woodwould.
14th May 2009, 03:32 PM #6Member
- Feb 2009
- 46
- 96
14th May 2009, 03:45 PM #7
Imagine the fun you could have with dual control knobs so you could set a neutral or carburizing flame! mending pots would be a cinch.
Barbequeues would be much more fun as you and your mates could braze little Johnny's bicycle frame and that cast iron manifold that's been the shed's door stop for the past ten years, all while the snags sizzled in double quick time.
The Missus could use the gas axe to brown the top of the Sunday desert..
Regards, Woodwould.
Carbon arc torch
By scooter in forum METALWORK GENERALReplies: 11Last Post: 24th Jun 2008, 09:20 AM -
Who has an oxy cutting torch ?
By Grahame Collins in forum METALWORK GENERALReplies: 33Last Post: 18th Oct 2007, 02:58 PM
