Results 1 to 5 of 5
25th Mar 2009, 03:34 PM #1Member
- Jul 2007
- Ipswich
Metal replacement gears for the Sieg mill & lathe
Hi, somewhere I have seen people replace the plastic gears in their Sieg lathe & mill with metal ones...
are these available commercially, and if so has anyone bought and used them.. how good are they, what were the costs (all the accessories are now worth more than the machine) and where dod I get them..? Local or international.?
Andy
26th Mar 2009, 12:02 PM #2Senior Member
- Canberra
- 184
No idea what's available locally, but if you want to import little machine shop has that sort of stuff
http://littlemachineshop.com/
26th Mar 2009, 12:06 PM #3Golden Member
- home
- 621
For the mill, forget the metal gears and just get the belt drive.
Not sure if any of the Sieg lathes have plastic gears. My C6 has only metal gears.Geoff
The view from home
27th Mar 2009, 11:23 AM #4Member
- Sep 2008
- Prince George BC Canada
- 89
It's the 'fuse'
Just a word of caution about replacing plastic gears with metal ones...... in many cases the plastic gear is considered a sacrificial gear and is designed to fail under "catastrophic" failure. This is to prevent a greater damage to other less replaceable parts in the drive. It acts as the ''fuse' to prevent even more serious damage.
JMHO
alRemember if the ID exceeds the OD the hole will be on the outside!
4th Apr 2009, 09:02 PM #5Member
- Jul 2007
- Ipswich
Thanks for the info bough belt drive
Hi,
have just ordered the belt drive upgrade kit for my Sieg X2 mill. not arrived yet.
Thanks to all for the input.
regards,
Andy
anyone fitted DRo to a Sieg X2 mill
By Nurgle in forum METALWORK GENERALReplies: 10Last Post: 18th Apr 2009, 11:30 AM -
Change gears for Hercus lathe model C?
By neksmerj in forum THE HERCUS AREAReplies: 1Last Post: 20th Jul 2008, 01:03 PM -
New C4 Sieg mini lathe with 1000W motor
By Mybrains in forum METALWORK GENERALReplies: 1Last Post: 5th Dec 2007, 11:06 AM
