Results 1 to 7 of 7
Thread: Boxford Lathe - Back Gear
5th Feb 2009, 04:59 PM #1Intermediate Member
- Sep 2008
- AlphaCentauri
- 29
Hi Guys/Gals,
I recently bought a Boxford CSB Lathe - think it's a 1960's model - in good condition.
It's a clone of the SouthBend models and I think it's close to some of the Hercus models as well.
I just want to know - is it normal not being able to spin the chuck by hand when the backgear is engaged?
5th Feb 2009, 06:06 PM #2Most Valued Member
- 4,887
yes
5th Feb 2009, 10:20 PM #3Intermediate Member
- Sep 2008
- AlphaCentauri
- 29
Now an even sillier question.
Is'nt the backgears function to slow down the spindle speed?
6th Feb 2009, 01:37 AM #4Most Valued Member
- 4,887
Yes usually around 7 to 1 .
6th Feb 2009, 10:44 AM #5Most Valued Member
- Charlestown NSW
- 1,669
From your question, I'm assuming you haven't had a lot of experience with lathes yet. (If thats the case, thats ok, you have to start somewhere) I'f I'm wrong I apologise.
Anyway, when you engage the back gear, don't forget to pull the pin that connects the spindle pulley to the spindle. Otherwise you definately will not be able to turn the chuck by hand. Or with the motor either.
Also don't forget to lube the spindle when the pulley is running in back gear mode. There should be a lube point somewhere. probably on the pulley. It might be a hole with a grub screw that you have to remove to squirt a bit of oil in then replace the grubscrew.
best of luck with it.
regards
bollie7
6th Feb 2009, 08:06 PM #6Intermediate Member
- Sep 2008
- AlphaCentauri
- 29
Well, to be honest, I have never worked with a lathe before. I managed to run it with the backgear engaged last night.
Thanx everyone for the helpful advice,
6th Feb 2009, 11:09 PM #7
I get the impression that you expected it to be EASIER to turn the chuck with backgear engaged, don;t forget that to gear DOWN the chuck from the drive (motor), means that turning the chuck is geared UP, as you are trying to turn the motor over 7 times faster than "normal"
BillChipslinger
Rebuilt back gear
By bitza500 in forum THE HERCUS AREAReplies: 0Last Post: 19th Oct 2008, 08:41 PM -
Replacing back gear assembly on Hercus 9" lathe.
By mob in forum THE HERCUS AREAReplies: 3Last Post: 23rd Sep 2008, 11:35 PM -
Metal gear / worm gear needed
By colinshannon in forum METALWORK GENERALReplies: 14Last Post: 29th Mar 2007, 10:49 PM
