Results 1 to 7 of 7
    Oct 2005
    Brisbane
    7
    Default copper wire, flux removal
    Hi, I am looking for something to remove excess flux after soldering copper wire. I haven't done any soldering before and the tutorial recommends flux remover so that the copper wire can be patina'd. The one welding shop I found, didn't know what I was talking about, which is probably understandable since I hardly knew what I was asking for!
    Kym
    Mar 2008
    Newcastle West Australia
    197
    Just some soapy water should do the trick or depending on the size of the project some soapy water or metho on a cotton wool bud.
    www.solidwoodfurniture.com.au
    A good edge takes a little sweat!!
    Oct 2005
    Brisbane
    7
    Thanks, I will try your suggestions. I am going to use .5 to 2mm copper wire, nothing very big. Just a matter of putting joins in the wire.
    Kym
    Quote Originally Posted by Claw Hama View Post
    Feb 2008
    far south coast nsw
    84
    57
    Default soldering
    Gday kym: you mmay find this a help.www.efunda.com/materials/solder/guidelines.cfm
    billym
    Oct 2005
    Brisbane
    7
    I learnt something. Solder clean metal. Some of it was very technical but I should make sure the copper is not oxidised so clean it well first. Solder quickly and with as low a temp that will do the job. Pretty good tips so thanks!
    Kym
    Sep 2005
    Cheltenham, Melbourne
    74
    182
    Flux remover is used a lot on circuit board making, so both Dick Smith, & Jaycar, should have it.
    Life isn't always fair
    ....................but it's better than the alternative.
    Sep 2002
    Minbun, FNQ, Australia
    66
    2,012
    Flux Remover fumes can be toxic, particularly if they get near a naked flame.
    Metho & a toothbrush is a bit slower but much safer.
    Cliff.
    ...if all you have is a hammer, everything looks like a nail...
  1. Copper to copper
    By slepax in forum WELDING
    Last Post: 19th Oct 2008, 04:10 PM
  2. Machining copper?
    Last Post: 5th Nov 2007, 10:31 AM
  3. Solder Flux?
    By Walesey in forum METALWORK GENERAL
    Last Post: 19th Jun 2007, 05:54 AM
