Results 1 to 15 of 15
Thread: Drilling M2
    Jun 2007
    Toowoomba, Qld
    31
    0
    Default Drilling M2
    I'm gonna make some carving knives from M2 steel from McJings so I'll need to drill some holes in the M2 about 3mm diameter.
    How shall I do it?
    Jun 2007
    sydney ( st marys )
    64
    4,890
    With a drill.
    Apr 2006
    near Mackay
    59
    215
    I drilled a 1/8" (approx 3mm) hole in one of my D2 plane blades no problems.
    I used a solid carbide drill bit and plenty of cutting compound, and drilled in short bursts so as not to get too hot.
    I dont know how a HSS drill bit would go, maybe try on a waste piece first, just be carefull not to overheat the drillbit.
    Apr 2008
    NSW
    537
    I have heard people say that you can drill a hole in HSS with one of those glass & tile drills that you get from the hardware store.
    Although I have never tried it myself so I can't say for sure.
    Mar 2008
    South Coast, Australia
    63
    225
    I have successfully drilled 3/16" holes through hardended stainless several times using an el-cheapo carbide-tipped masonary bit and a bit of cutting fluid or WD 40 or oil.
    He Who Dies With the Most Tools Wins
    7,189
    Most HSS is M2 or a similar alloy of a similar hardness, so HSS is not going to drill into . I have also heard about the tile drill and carbide bits but have not done it myself.
    What I do instead of trying to drilling holes in hard steel if I want to add a handle is to cut small slots in it using a fine kerf cut off wheel. The handle bolts or screws fit in the slots and there are various geometrical arrangements you can use that will allow you to lock a blade into a handle with just one screw if you need to. This is much easier than drilling - see picture below which uses 3 slots and 3 screws. The little gaps left behind can be filled with a sliver of wood or an interesting piece of something like brass or even just casting resin.
    Jun 2007
    Toowoomba, Qld
    31
    0
    Most HSS is M2 or a similar alloy so this is not going to do it. I have also heard about the tile drill and carbide bits but have not done it myself.
    What I do instead of trying to drilling holes in this stuff for handles is to cut slots in it using a fine kerf cut off wheel. The handle bolts or screws fit in the slots and there are various geometrical arrangements you can use that will allow you to lock a blade into a handle with just one screw if you need to. This is much easier than drilling - see picture below. The little gap left behind can be filled with a sliver of wood or an interesting piece of something like brass or even just casting resin.
    Mmhmm..So you'd have a screw that hits the slot and pushes it into the handle and holds it there?
    Dec 2007
    Clareville nsw 2107
    11
    A 3mm ARTU drill bit with a little cutting oil will go through just about anything.
    Costs about $5.
    https://www.bolt.com.au/product_info...ducts_id=91964
    Mike
    www.ColonialPlantationShutters.com.au
    Use your garage or home workshop to make Plantation Shutters as a business
    Feb 2007
    Katherine ,Northern Territory
    69
    736
    Years ago when I worked in toolrooms ,we had stellite drills for drilling hardened tool steels .
    They basically were a triangular shape with rounded sides ,not much of a flute just a hollow along the sides no twist .
    But you drove them at high speed until the material you were drilling turned red hot and then put pressure on the drill and it would punch straight through.
    I haven't seen these drills for along time .Not sure if they are still available or even used these days.
    Kev
    "Outside of a dog a book is man's best friend ,inside a dog it's too dark to read"
    Groucho Marx
    Jun 2008
    minto
    74
    40
    A COBALT DRILL WILL DRILL HARDENED STILL UP to about 55/60 rockwell at slow speed with juice
    7,189
    Quote Originally Posted by beetle View Post
    M2 or HSS is typically Rc61 - 63 so cobalt drills are not going to do it either.
    I just tried using a cheap chinese carbide tipped masonry 7/32 bit to drill a hole through a 3 mm thick piece of M2. Touched the carbide tip up on a grinder, so it has a fresh edge, lots of standard metal working soluble oil/water lube, high down pressure on the DP and it went through in about 20 seconds, the steel flakes off as you would expect from a hard material. Cleanish hole on one side, bit ragged on the other - there are probably more optimum cutting angles on the drill than for masonry - but hey it worked!
    Jun 2008
    minto
    74
    40
    I meant hardened steel
    7,189
    I kind like the idea of a "hardened still" - sounds like something that could have handled great uncles potato skin based hooch making activities without blowing up every coupla months. Man that stuff was like dynamite.
    Jun 2008
    minto
    74
    40
    WE could build a stilll
  15. #15
    7,189
    Quote Originally Posted by funkychicken View Post
    or even just like this. ie screws going in/out of screen.
