Results 1 to 2 of 2
Thread: Combination Lathe and Mill
22nd Sep 2008, 08:58 PM #1
Does anyone own a combination Lathe and Milling Machine size around 200 mm swing over the bed 400 mm between centres similar to one available at Gasweld , question how have you found the performance and accuracy
Constant Sinking Feeling
22nd Sep 2008, 09:07 PM #2
Yes.
The lathe is as expected for price. Basic but seems to work OK.
Accuracy I can not state as have not tried to be accurate yet.
The mill is a good drill. flexes a little bit as a mill.
The big problem is the drill does not come all the way down to the little vice.
Needs a higher vice. About $60.
Cost a heap more for some good tools.
Mini lathe/mill projects?
By neksmerj in forum METALWORK GENERALReplies: 7Last Post: 28th Feb 2009, 01:47 PM -
Which would you spend more on lathe or mill?
By hux in forum METALWORK GENERALReplies: 9Last Post: 30th Apr 2007, 07:28 PM -
Lathe /Mill
By DavidG in forum METALWORK GENERALReplies: 7Last Post: 11th Nov 2006, 08:21 AM -
Combination lathe & milling machines?
By Chris.s. in forum METALWORK GENERALReplies: 5Last Post: 12th Jul 2005, 04:44 PM
