Results 1 to 6 of 6
Thread: Rivets.
27th Jun 2008, 03:17 PM #1Retired
- May 1999
- Tooradin,Victoria,Australia
- 73
- 5,457
Rivets.
Gooday all.
I was wondering if some one on the forums can help me locate some rivets.
I think they are called "kinsman or kinsmen".
They are a solid aluminium rivet that have to be set.
I am after 5/32" approx 3/8" and 1/2" long.
Thanks for all help.
This is also posted in "Nothing to do with woodwork forum".
27th Jun 2008, 04:15 PM #2
there were some advertised on ebay recently.I have just gone and had a search now and there are non listed but keeping an eye on ebay couldnt hurt. I hope this might help you.
Warning Disclaimer
27th Jun 2008, 04:48 PM #3
Hi Robbo,
I believe they are more commonly called Brazier Solid Rivets. Brazier being the low domed head profile. I think the naming is another US of A thing.
They are also available in several other profiles.
Below are a couple of places that stock that sort of stuff.
http://www.rivetsinstock.com/rivet17.htm
http://www.rjleahy.com/Store/rivets/arvb.htm
If it were me, I would first try Nepean Boltmaster.
I am usually surprised by the oddball stock they carry.
http://www.nepbolt.com.au/products.php
27th Jun 2008, 05:43 PM #4
Robbo ring my SIL's work "Thomas Watburton" Mulgrave branch on 9574 3434
They have in stock 4500 countersunk ones and can supply Mushroom heads if required.
Cheersregards
David
"Tell him he's dreamin.""How's the serenity" (from "The Castle")
27th Jun 2008, 09:49 PM #5Senior Member
- Oct 2003
- Sydney,Australia
- 174
"Tinsman's" rivets - 'cause they were used by tin workers.
Now, if you were able to use 'iron' or galvanised 'iron' flat head rivets, I might be able to help. 1/8" (3mm) you can use common clout nails & a pair of mini bolt cutters. For 3/16" I'd say, 'Flat or domed? 1,000 or 9,000? - in the green toolbox in the shed.
28th Jun 2008, 10:18 AM #6Retired
- May 1999
- 73
- 5,457
Thank you for your help gentlemen. Will check it out Monday and let you know how I got on.
Brslee: unfortunately they have to be aluminium.
