Results 1 to 8 of 8
Thread: MT-3 slitting saw arbors
28th Mar 2008, 02:03 PM #1New Member
- Jul 2007
- tasmania
- 9
Hello everyone,
Have just ordered a HM-45 mill from Hare and Forbes. I'm after a slitting saw arbor to fit it(MT-3). H+F don't stock them. Does anyone know of an Australian supplier who does? I've googled for a couple of hours with no luck.
Dave
28th Mar 2008, 04:39 PM #2Intermediate Member
- Mar 2005
- Jindabyne
- 74
- 40
Try McJings in Yagoona they have stuff not listed on the website and are most helpful.
Give em a ring and ask they will have a look, and will mail if you can't pick-up. Guess you won't be able to pick-up just saw you're in Tassie.
CheersBrian
Creator of Fine Firewood
28th Mar 2008, 05:57 PM #3Most Valued Member
- 4,890
People will say you shouldnt do this but have you thought of adapting a No2 to fit a No3 shank,you can weld the 2 to the 3,you may have to adjust the end of the 2 to fit.
If you have access to a lathe make your own.
28th Mar 2008, 09:14 PM #4
Generally some listed in metalwork, woodwork section under Business Industrial on ebay. Looked just now and could only find R8 ones from England. Someone in Vic often lists them, also does swap meets etc .
29th Mar 2008, 04:39 AM #5Most Valued Member
- 4,890
Check ebay a shop in UK has MT3 multi fit bore size 1/2"-1" with 3/8 draw bar,under $40 to get it here.
2nd Jun 2008, 09:53 PM #6
Look on Ebay as there is a supplier of these in the uk. I bought one of them and the item arrived all well and good in 12 days.top quality tooling at an affordable price.I think postage was only about $12.00 their Ebay name is TOOL TIMES.Hope this helps Matt
3rd Jun 2008, 01:26 AM #7Product designer retired
- Nov 2006
- Heidelberg, Victoria
- 79
- 2,074
Closer to home, check out item #170224514986 on eBay. (tissuescars)
The one he has advertised is an MT2, but if you contact the seller, you might be in luck.
I purchased an MT3 arbor, 1" dia, from him just recently, new and less than $40, I think.
Ken
3rd Jun 2008, 12:16 PM #8
Cheapest way, assuming you have the MT2 version of the arbor - if not thy're easy to find, is to get an MT3 to MT2 adaptor. Try McJings www.mcjing.com.au
Bodgy
"Is it not enough simply to be able to appreciate the beauty of the garden without it being necessary to believe that there are faeries at the bottom of it? " Douglas Adams
Slitting coiled wire
By Hamish Lonsdale in forum JEWELLERYReplies: 10Last Post: 28th Oct 2007, 08:49 PM
