Results 1 to 8 of 8
Thread: Stainless steel hex bar
17th Feb 2008, 10:35 PM #1Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Anybody know where I can get small lengths( 300mm or so) of s/s metric hex in Australia? I think the sizes I need are 16 mm and 19 mm.
Tried Ebay and Google.
I want to make some filler/ drain plugs for one of my m/bikes and they should fit metric spanners, etc.
Stephen
17th Feb 2008, 10:58 PM #2Most Valued Member
- 4,890
Hello Stephen if you have too much trouble finding what your after in W.A,I would more than likely be able to source material and get it posted to you.
Short of that can you get hold of some round stock and mill the flats,or use imperial 5/8" is only .004" smaller than 16mm and 3/4" is only .002" smaller ,shouldnt be a great deal of slop for a ring,openender or socket.
Is your main problem material sizes or getting it cut to length.
18th Feb 2008, 02:01 AM #3Golden Member
- May 2003
- 526
Hi Steve,
BÖHLER-UDDEHOLM are the most likely source in Perth.
cheers,
RodCheers,
Rod
18th Feb 2008, 08:23 AM #4
Offcuts Galore sells offcuts of sheet, rod, tube and bar in various metals including stainless. He tends to list stainless steel using the abbreviation SS and this may explain why you didn't find him on an eBay search.
There is no hex listed at the moment, but the listing tends to be updated once or twice a week, so it pays to keep an eye out. When I buy from him, I tend to buy several pieces of metal of different kinds at once - George (the owner) is happy to combine the postage and the saving becomes quite significant if you have 4 or 5 pieces to buyCheers
Jeremy
If it were done when 'tis done, then 'twere well it were done quickly
18th Feb 2008, 11:56 AM #5Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
20th Feb 2008, 11:42 PM #6Senior Member
- Feb 2007
- brisbane
- 245
I will second Bohler (www.buau.com.au) as a good source. They are a pretty large outfit.
I was at their Brisbane branch today picking up some 90 & 70mm 1045.
I see a golf ball launcher on my horizon.
Be aware they have minimum sale price of $50 so you will probably need to work out what else you need to get the order value up.
Since you have a lathe there is no doubt there would be other steel you need.
Haven't used Global Metals but they are also in WA
51 Charles Street, Bentley - WA 6102
PO Box 1046, East Victoria Park - WA 6101
T: +61 8 9451 4733
F: +61 8 9451 4755
E: [email protected]Cheers
Craig
Brisbane
21st Feb 2008, 11:50 AM #7Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
Thanks Hux, I will check them out.
21st Feb 2008, 11:28 PM #8Senior Member
- Jul 2007
- 332
Sterob, Another place to try is Prime Steel, Townsend St, Malaga, 92482666 they deal in off cuts of many metals. Not cheap but they will cut to length if req. No connection but do get some stuff from there. Alan.
Stainless Steel or 4140
By Dusty Wheels in forum METALWORK GENERALReplies: 9Last Post: 27th May 2007, 11:23 AM -
Stainless Steel welding
By Clinton1 in forum WELDINGReplies: 15Last Post: 6th Apr 2007, 01:58 AM
